1st March February 2012
Latest post 02-12-2009 11:43 AM by Quim43. 387 replies.
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Re: BV7 40 MKIII / SW 4.24 problem
well i have been into the office and made a scart lead instead of having a horrid cable on the floor for the last few months and put it in STB working properly now "i was nto aware the STB needed scart to work it never used to pre 4.24a Now i sit and wait for a crash to off to happen lets see.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
msinn
- Joined on 12-11-2007
- Germany
- Posts 48
If a SCART connection is required to control a STB, two questions arise for me: 1. How do I control a STB or Blu-ray player which has no SCART connector? 2. How do I connect more than 3 STBs to an BS3? A BS3 has only 3 SCART connectors. Greetings Martin
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
msinn: If a SCART connection is required to control a STB, two questions arise for me: 1. How do I control a STB or Blu-ray player which has no SCART connector? 2. How do I connect more than 3 STBs to an BS3? A BS3 has only 3 SCART connectors. Greetings Martin
You only need scart connection if you would like the STB to turn on/off when the tv turns on/off, other requirements are link rooms, and teletext. If you don't need any of these, then you don't need a scart connection. I have a PS3 connected via HDMI, and it works fine with my NYKO remote. However BV7 and SW4.24a has an issue which causes the BV7 to crash when watching a HDMI source which is not connected via scart also. B&O is looking in to this and more errors. However my BV4 is not affected by this crash, and i also have sw4.24a, so it is a BV7/4.24a issue as i see it. /Weebyx
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Weebyx:I have a PS3 connected via HDMI, and it works fine with my NYKO remote. However BV7 and SW4.24a has an issue which causes the BV7 to crash when watching a HDMI source which is not connected via scart also.
I don't know if this is exactly true. I have an STB connected by both HDMI and scart and I experience the crash-off issue all the time. Probably three times over the weekend. So, I don't think the crash-off issue is due to a none-connected scart lead.
Seanie_230
- Posts 962
hay there i also have scart and HDMI connected and it crashes to off all the time
Weebyx
- Denmark
- Posts 321
moxxey: Weebyx: I have a PS3 connected via HDMI, and it works fine with my NYKO remote. However BV7 and SW4.24a has an issue which causes the BV7 to crash when watching a HDMI source which is not connected via scart also.
Hmm, i just thought we had narrowed it down to the missing SCART connection ? Then it must be when using HDMI the problem exists, i had my STB connected only through SCART and it was only when using my PS3 or mediapc via HDMI(no scart) i had the crash-to-off feature. It never chrashed when watching my "old" stb which doesn't have HDMI. But one thing i don't understand though, the BV7 should be based on the same BS3 as my new BV4, but i have now had the BV4 for over a week, and it has not turned off once! And i have been using it mostly for my mediaPC which almost certanly crashed the BV7 at least once every night. Something is different in the stand-alone BS3 and the one in the BV7, that is my conclusion. /Weebyx
Seanie_230
- Posts 962
i love the way were all calling it a Crash To off Feature like its supposed to happen lol, its a crash to off problem my tv was re-updated using service tool 5.2.6 MKII on saturday and has lost sync already with SKY you were saying that you only used HDMI before 4.24 and did the stb work properly without a scart lead being connected?
Weebyx
- Denmark
- Posts 321
seanklemis: i love the way were all calling it a Crash To off Feature like its supposed to happen lol, its a crash to off problem my tv was re-updated using service tool 5.2.6 MKII on saturday and has lost sync already with SKY you were saying that you only used HDMI before 4.24 and did the stb work properly without a scart lead being connected?
Since B&O hasn't found a solution, it must be af FEATURE :). Before 4.24 i never experienced the crash when using my PS3 og mediaPC only connected via HDMI. /Weebyx
Weebyx
- Denmark
- Posts 321
Quim43:I have a Tvix 4100 connected to my BV7 Mk3 via HDMI. I have also a Sat Decoder connected via scart. Two weeks with the new SW 4.24a and still no crashes. As I said before in this thread, I think the problem is the way how the TV was updated, automatically or manually.
Well, i have had 2 BV7's one that was upgraded to 4.24a=crash, and one that came with 4.24a installed from factory=crash. My new BV4 with 4.24 from factory = no crash. Go figure :) /Weebyx
martin01
- Joined on 04-17-2007
- Sweden
- Posts 207
I have e-mailed B&O in Struer about the Crash-problem. I got the answer today. They say that they are working on a SW 5.0 which will be released "soon". We now what "soon" means. They could not say if this new sw will solve the crashproblem. So we have to wait further for the sw 5.0 and see if this will help. /Martin
Beolab 5 with sw 3.0, BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
BEOKNOW
- Joined on 09-11-2008
- Posts 59
I have it on good authority that software 5.00 will cure the shutdown when connected to Sky HD etc. A skart is required for correct operation of Sky HD box.
Seanie_230
- Posts 962
Hello Just spoke to one of my dealers and im told SW 5.?? is expected in about 6 weeks so thank god? i do wonder what else it will cure and what else it may break
vlohjr1
- Joined on 06-26-2007
- Posts 106
a curious question probably off topic does your original software version that comes with MKII in sync with SKY HD box? It is completely out of sync with mine and i have gone back to the old HD box. My suspicion is more of the SKY box rather than BV7 itself? thanks Vince
Seanie_230
- Posts 962
hi there i had a MK2 and mine got out of sync because the scart lead had come loose double check that
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
My BV7 Mk3 was updated to 4.24 few weeks ago, with no crashes till now. The only diference I can see now is that I changed my mediacenter. I had a Tvix 4100SH connected by HDMI 1.1. I changed it for the new Tvix 6500 with HDMI 1.3 and now my TV crashes. Do you know if this can be the fault, HDMI 1.3 instead of 1.1? Regards
moxxey
- South West, UK
- Posts 2,360
No idea. I don't think the Sky box (which causes my problem) is a 1.3 device? I'm getting a little fed up with the time taken to fix this issue. It's been ongoing since July. My TV seems to crash-off at inopportune moments, such as a good scene in a movie or watching football.
Seanie_230
- Posts 962
hi moxxey i know how you fell and i am waiting until the end of the month as we were told there will be software 5.xx then that shoudl fix the problem i know from a local dealer that according to the B&o info pages they have there is now a note saying that anyone will problems shoudl downgrade there software to 4.17 but i am not going to do that i am waiting, some days its worse than others. the lack of communication is the worst part i can understand if they have some problems but a little feedback woudl be nice rather than deny all knowledge of a problem. might call my dealer in a mo just to see if he has heard anymore
Weebyx
- Denmark
- Posts 321
seanklemis: hi moxxey i know how you fell and i am waiting until the end of the month as we were told there will be software 5.xx then that shoudl fix the problem i know from a local dealer that according to the B&o info pages they have there is now a note saying that anyone will problems shoudl downgrade there software to 4.17 but i am not going to do that i am waiting, some days its worse than others. the lack of communication is the worst part i can understand if they have some problems but a little feedback woudl be nice rather than deny all knowledge of a problem. might call my dealer in a mo just to see if he has heard anymore
Just talked to my dealer, and he told me that there was no release date on the B&O intranet, regarding the new sw. But since they have made a statement now, they has accepted that they are having this problem :) I bet they are working like rabbits are bang.... on solving the problem. Let's just hope that the new sw will be released within 3-4 weeks tops. I am beginning to experience the crash problem on my BV4 also, however it has only done it 2 times in the last 3 weeks. So i am waiting for the next release. /Weebyx
Weebyx
- Denmark
- Posts 321
Hi, i just talked to my dealer a few minutes ago, and he told me that the 5.0SW is due in the next week or so. /Weebyx
Seanie_230
- Posts 962
have they said what the new SW will fix?
Weebyx
- Denmark
- Posts 321
seanklemis:have they said what the new SW will fix?
The shut off issue should be solved. Other than that he didn't have the list yet. /Weebyx
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Any other news from anyone on the new software?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
I have also heard that 5.x will be coming 'in November'...so we shall see...this being the US and all. As an aside to all of you experiencing the 'crash to off' issue, B&O stipulates that the problem is only occuring with HDMI connected devices. I know that the connection panel on the EU BS-3/BV-7 is a bit different from ours (SCARTs instead of RCA/phono), but a worthwhile temporary fix over here would be to go back to the component video/analog audio cables...usually supplied for free with the device.
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Weebyx
- Denmark
- Posts 321
RussR: I have also heard that 5.x will be coming 'in November'...so we shall see...this being the US and all. As an aside to all of you experiencing the 'crash to off' issue, B&O stipulates that the problem is only occuring with HDMI connected devices. I know that the connection panel on the EU BS-3/BV-7 is a bit different from ours (SCARTs instead of RCA/phono), but a worthwhile temporary fix over here would be to go back to the component video/analog audio cables...usually supplied for free with the device.
And miss out on the HD channels and HD PS3 gaming, and HD mediacenter PC, i think not ! I will just wait and see what happens next week, if the SW isn't available friday next week, i will ask my dealer to downgrade to 4.17. Then the problem is solved. /Weebyx
