1st March February 2012
Latest post 02-09-2012 10:08 AM by Stan. 138 replies.
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Re: Your latest purchase?
elephant:
tournedos:
elephant: Never seen those before.
You should have, they have been a prize draw item not so long ago
well no Prixe Draw complaints from me !
so I wonder if Struer has a gift shop ...
If they sell them, pick me up a pair when you're there!!! (I'll pay you back of course)
My B&O: 2009 Catalogue and Pricelist
BeoMegaMan
- Joined on 11-25-2007
- Posts 66
I purchased a BS2000 Red for $75 with stand in mint condition. CD mech doesn't work but it also came with a Beo4 and aux cable. Gonna use it for a garage radio I think:)
BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
Dennis
- Joined on 02-01-2009
- Denmark
- Posts 172
Hi again!
Guess what! Last week I bought something again and I recieced it today! I have bought a MPAV 9000 for my AV9000! But I sadly still have to buy a MasterLink cable before I can start using it. I am also going to buy a wall bracket for it as I have planned to mount the MPAV on the wall next to my sofa. I will post a picture when I have finished the installation.
- Dennis
I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
Stoobietoo
- Joined on 03-28-2008
- Exeter UK
- Posts 145
Chris:
What the best way to connect this to our Beovision 7-40 mk3 in an adjacent room? Is their a radio/IR Masterlink or is it yet more cables?
You could buy a pair of beolink Wireless 1's and do it that way. Not cheap though! It is a neater option than running cable if you can't hide it! Cable is more robust, but I have not had problems with the Wireless 1 although others have!
Take a look at my little project - link
Stoobie
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Be sure to buy a special ml cable... Not the Standard one! Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Dennis
- Denmark
- Posts 172
Thanks for the warning, kallasr! Can you tell me how I can recognize the right ML cable? If it's recognizable!
- Dennis
kallasr
- Posts 1,077
LINK might be helpful.
Ralf
Dennis
- Denmark
- Posts 172
tompa:
You can use the normal masterlink cable but you have to make a short circuit between pin 4 (ML sense)and 12 on masterlink socket in MP AV9000 stereo
that have bin done in struer from serial number 10822537.
Can anyone confirm, that this will work? Cause then I'm going to make that operation (If the Serial Number is lower than 10822537)! when I'm opening the MPAV 9000 sometime to adjust the doors.
- Dennis
kallasr
- Posts 1,077
In this thread it is pin 4 and 6....
Wait for the experts...
Ralf
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
Allmighty BL9
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
A pair of S120's.
Actual condition is worse than the photo's suggest so some work required here methinks...
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Holy crap Chris, that's a challenge!
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Dennis
- Denmark
- Posts 172
tompa:
Ulf:
Nö,
geht auch mit den neueren ML Kabel: Man muss "nur" im MPAV die ML Buchse PIN 4 mit PIN 6 brücken.
Ulf wünscht frohes Fest
I think this is Ulf's website, and I am very impressed of his Bang & Olufsen section, fantastic work! It seems that Ulf's knowledge is quite big on this area. Can you confirm if it's either PIN4+6 or PIN4+12 that needs to be connected, Ulf?
- Dennis
Leslie
- Netherlands
- Posts 2,201
Dennis (Loudspeaker):
He is fantastic, seen and heard many good things about Ulf!
Medogsfat
- Posts 4,045
Leslie:
Bigger than you could imagine. One of the Bass drivers wasn't working but thanks to a tip from Martin (detached flexible wire to the voice coil which required some pretty painstaking dismantling & resoldering) at least that is now fine.
The usual refoaming will be next followed by a recap.
Then some of the retaining pegs are missing from the frets which I'll need to "re-manufacture" so to speak.
Finally the cabinets - I haven't yet decided on a course of action. They have been allowed to get damp which has caused the bottom joints to swell & part. That's before I even consider any remedial repolishing, but rest assured I'll get there.
Chris.
Friedmett
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
Chris I could use all retaining pegs for my Beovox M150 covers. All 4 of them in total. They are all broken.
So if you find a solid solution please send a pm. My CDX still works since you did lefthinge some years ago.
I'm glad my Beovox S120 only had rot and my Bevox M150 are scratched but not deep. I do hope you do a thread with clear instructions on the rebuild of yours.
Anyway congratz when finished you are in for a treat.
Leslie
- Netherlands
- Posts 2,201
Medogsfat:
Leslie:
Chris.
Wish you all the best with restoring and please show me (us) the results will you? I'm also interested how you re-manufacture the pegs!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Medogsfat: Then some of the retaining pegs are missing
I
think I once read about somebody making them from plastic wall plugs.
Find a suitable size, cut to length and epoxy in. Even available in
black if you look around
Leslie
- Netherlands
- Posts 2,201
That's a good idea Will work on that unless somebody else has a better idea!
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
For repairs to the broken front grill pins, I've seen wooden dovel pegs used instead. Remains of the old pins removed and ground down, dovel pegs glued to the grills and painted black. Worked fine.
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Dillen:
I did something like that with M70s, though I didn't paint the dowel. I reinforced the joint by "pinning" it.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Medogsfat
- Posts 4,045
tournedos:
Medogsfat: Then some of the retaining pegs are missing from the frets which I'll need to "re-manufacture" so to speak.
I think I once read about somebody making them from plastic wall plugs. Find a suitable size, cut to length and epoxy in. Even available in black if you look around
This is the method I've used before using plasterboard plugs with the expanding ends cut off & shaved slightly, a bit hard to explain without pictures. Done properly there's a method to also screw these onto the post seats to ensure a really good fix. I'll probably post something in the workbench section as this restoration progresses.
Chris.
Leslie
- Netherlands
- Posts 2,201
Just finished mine thanks to you guys!
EdouardG
- Joined on 04-21-2007
- Toulouse, France
- Posts 339
Hi folks,
I bought some B&O stuffs this last 2 months:
BV10-40
BS8
BeoTime
Beo6
Orange frames for BS8
PL MK3 + HDMI cables + socks from Steve (SoundsHeavenly)
...and third party stuffs:
Dvico TVIX Slim S1 Duo HD Wifi
Re-Bl X dongle to control my PS3 from Beo6
...and now, think about new Beocom 5 + Beocom 2 to replace my current Beocom 4, and some light dimmers...
Well, my Visa card doesn't stop crying these days....
Cheers,
E d o u a r d G
- Beovision 10-40 Orange MkII / Motorised stand / DVB HD T2/C MkIII
- Beolab 5 Black
- Beosound 8 Black
- Beocom 2 MkII (Polished Alu)
- Earset 2
- Earset 3i
- Form 2 Black
- Beotime (Alarm Clock)
- Keyring
- Beo 6 / Wall charger
- Beo 4
°°°°°°° 2nd Prize Draw Winner - November '11 / Beolab 3000 N.O.S °°°°°°°
