Latest post 02-09-2012 10:08 AM by Stan. 138 replies.
Page 4 of 6 (139 items) « First ... < Previous 2 3 4 5 6 Next >
  • 08-30-2011 8:04 PM In reply to
    Re: Your latest purchase?
    elephant:
    tournedos:
    elephant:
    Never seen those before.
    You should have, they have been a prize draw item not so long ago Big Smile
    well no Prixe Draw complaints from me !
    so I wonder if Struer has a gift shop ...
    Idea Gift Big Smile
    If they sell them, pick me up a pair when you're there!!! (I'll pay you back of course)
    Big SmileYes -  thumbs up
    My B&O: 2009 Catalogue and Pricelist
  • 08-30-2011 11:40 PM In reply to
    I purchased a BS2000 Red for $75 with stand in mint condition. CD mech doesn't work but it also came with a Beo4 and aux cable. Gonna use it for a garage radio I think:)
    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
  • 09-12-2011 1:35 PM In reply to
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    Hi again!
    Guess what! Last week I bought something again and I recieced it today! Big Smile I have bought a MPAV 9000 for my AV9000!  But I sadly still have to buy a MasterLink cable before I can start using it. I am also going to buy a wall bracket for it as I have planned to mount the MPAV on the wall next to my sofa. I will post a picture when I have finished the installation.
    - Dennis
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 09-12-2011 2:54 PM In reply to
    Chris:
    What the best way to connect this to our Beovision 7-40 mk3 in an adjacent room? Is their a radio/IR Masterlink or is it yet more cables?
    You could buy a pair of beolink Wireless 1's and do it that way. Not cheap though! It is a neater option than running cable if you can't hide it! Cable is more robust, but I have not had problems with the Wireless 1 although others have!
    Take a look at my little project - link
    Stoobie
  • 09-12-2011 4:09 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Be sure to buy a special ml cable... Not the Standard one!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 09-12-2011 4:35 PM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Thanks for the warning, kallasr! Can you tell me how I can recognize the right ML cable? If it's recognizable!
    - Dennis
  • 09-13-2011 2:48 AM In reply to
    • kallasr
    • Posts 1,077
    LINK might be helpful.
    Ralf
  • 09-13-2011 3:38 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    tompa:
    You can use the normal masterlink cable but you have to make a short circuit between pin 4 (ML sense)and 12 on masterlink socket in MP AV9000 stereo
    that have bin done in struer from serial number 10822537.
    Can anyone confirm, that this will work? Cause then I'm going to make that operation (If the Serial Number is lower than 10822537)! when I'm opening the MPAV 9000 sometime to adjust the doors. Smile
    - Dennis
  • 09-13-2011 5:47 AM In reply to
    • kallasr
    • Posts 1,077
    In this thread it is pin 4 and 6....
    Wait for the experts...
    Ralf
  • 09-13-2011 7:21 AM In reply to
    Allmighty BL9 Cool
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 09-13-2011 2:51 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    A pair of S120's.
    Actual condition is worse than the photo's suggest so some work required here methinks...
  • 09-13-2011 4:15 PM In reply to
    Holy crap Chris, that's a challenge!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-14-2011 5:44 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    tompa:
    Ulf:
    Nö,
    geht auch mit den neueren ML Kabel:
    Man muss "nur" im MPAV die ML Buchse PIN 4 mit PIN 6 brücken.
    Ulf wünscht frohes Fest
    I think this is Ulf's website, and I am very impressed of his Bang & Olufsen section, fantastic work! Smile It seems that Ulf's knowledge is quite big on this area. Can you confirm if it's either PIN4+6 or PIN4+12 that needs to be connected, Ulf?
    - Dennis
  • 09-14-2011 7:53 AM In reply to
    • Paul
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    have fun with sanding sanding and sanding!  New lacker and foamrings and have a look at the filter and they will be as good as new!
  • 09-14-2011 8:03 AM In reply to
    Dennis (Loudspeaker):
    He is fantastic, seen and heard many good things about Ulf!
  • 09-14-2011 11:31 AM In reply to
    • Medogsfat
    • Posts 4,045
    Leslie:
    Bigger than you could imagine. One of the Bass drivers wasn't working but thanks to a tip from Martin (detached flexible wire to the voice coil which required some pretty painstaking dismantling & resoldering) at least that is now fine.
    The usual refoaming will be next followed by a recap.
    Then some of the retaining pegs are missing from the frets which I'll need to "re-manufacture" so to speak.
    Finally the cabinets - I haven't yet decided on a course of action. They have been allowed to get damp which has caused the bottom joints to swell & part. That's before I even consider any remedial repolishing, but rest assured I'll get there.
    Chris.
  • 09-14-2011 11:54 AM In reply to
    Chris I could use all retaining pegs for my Beovox M150 covers. All 4 of them in total. They are all broken.
    So if you find a solid solution please send a pm. My CDX still works since you did lefthinge some years ago.
    I'm glad my Beovox S120 only had rot and my Bevox M150 are scratched but not deep. I do hope you do a thread with clear instructions on the rebuild of yours.
    Anyway congratz when finished you are in for a treat.
  • 09-14-2011 12:01 PM In reply to
    Medogsfat:
    Leslie:
    Chris.
    Wish you all the best with restoring and please show me (us) the results will you? I'm also interested how you re-manufacture the pegs!
  • 09-14-2011 12:24 PM In reply to
    Medogsfat:
    I think I once read about somebody making them from plastic wall plugs. Find a suitable size, cut to length and epoxy in. Even available in black if you look around Smile
    -mika
  • 09-14-2011 12:29 PM In reply to
    That's a good ideaYes -  thumbs up Will work on that unless somebody else has a better idea!
  • 09-14-2011 12:56 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    For repairs to the broken front grill pins, I've seen wooden dovel pegs used instead.
    Remains of the old pins removed and ground down, dovel pegs glued to the grills and painted black.
    Worked fine.
  • 09-14-2011 1:28 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Dillen:
    Worked fine.
    I did something like that with M70s, though I didn't paint the dowel.  I reinforced the joint by "pinning" it.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-14-2011 2:24 PM In reply to
    • Medogsfat
    • Posts 4,045
    tournedos:
    Medogsfat:
    This is the method I've used before using plasterboard plugs with the expanding ends cut off & shaved slightly, a bit hard to explain without pictures. Done properly there's a method to also screw these onto the post seats to ensure a really good fix. I'll probably post something in the workbench section as this restoration progresses.
    Chris.
  • 10-09-2011 9:23 AM In reply to
    Just finished mine thanks to you guys!
  • 10-09-2011 1:47 PM In reply to
    • EdouardG
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Toulouse, France
    • Posts 339
    • Gold Member
    Hi folks,
    I bought some B&O stuffs this last 2 months:
    BV10-40
    BS8
    BeoTime
    Beo6
    Orange frames for BS8
    PL MK3 + HDMI cables + socks from Steve (SoundsHeavenly)
    ...and third party stuffs:
    Dvico TVIX Slim S1 Duo HD Wifi
    Re-Bl X dongle to control my PS3 from Beo6
    ...and now, think about new Beocom 5 + Beocom 2 to replace my current Beocom 4, and some light dimmers...
    Well, my Visa card doesn't stop crying these days.... Big Smile
    Cheers,
    E d o u a r d  G
    • Beovision 10-40 Orange MkII / Motorised stand / DVB HD T2/C MkIII
    • Beolab 5 Black
    • Beosound 8 Black
    • Beocom 2 MkII (Polished Alu)
    • Earset 2
    • Earset 3i
    • Form 2 Black
    • Beotime (Alarm Clock)
    • Keyring
    • Beo 6 / Wall charger
    • Beo 4
          °°°°°°°  2nd Prize Draw Winner - November '11 / Beolab 3000 N.O.S  °°°°°°°
