1st March February 2012
Latest post 02-12-2009 11:43 AM by Quim43. 387 replies.
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Re: BV7 40 MKIII / SW 4.24 problem
Roger: Strange, BeoSystem 3 sw 5.00 build 431 was made available at 12:56 hrs (CET) today, November 21st. Roger
Not in Softwaretool MKII!!
BMGHB
- Joined on 05-12-2007
- Posts 219
I tried to update my servicetool MKII at 1500 today and there was no SW 5.0. Even though i was told it would be available today.. Maybe monday? BMGHB
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
kai
- Joined on 11-16-2008
- Posts 81
Vista media centre visa beo 4 beo 5
Hi Weebyx Could you tell me how you can control the vista media centre with beo4/5. I'm building a movie server, which will use vista media centre, and would like to control it with my Beo4, I did not think it was possible to do this. look forward to your reply Kai
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
Re: Vista media centre visa beo 4 beo 5
kai: Hi Weebyx Could you tell me how you can control the vista media centre with beo4/5. I'm building a movie server, which will use vista media centre, and would like to control it with my Beo4, I did not think it was possible to do this. look forward to your reply Kai
Take a look at this thread i wrote some time ago. http://forum.beoworld.org/forums/thread/159897.aspx /Weebyx
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
any news on this, did anyone manage to get 5.0 on the service tool or is it a component update for Bsystem 3
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
seanklemis:any news on this, did anyone manage to get 5.0 on the service tool or is it a component update for Bsystem 3
Version 5.00 Build 431. Release date 24-11-2008 Version 5.00 Build 431. Release date 24-11-2008
Seanie_230
- Posts 962
i shall be calling my dealer today but thats what i did with 4.24 and look where that got me. I hope i wont be posting on a thread called " Re: BV7 40 MKIII / SW 5.00 problem" any time soon can someone who has access to the service tool attach the list of Fixes as soon as they have download it please.
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
These are the new features | | | | | | · | Extended “sense” – senses changes on all video signals from peripheral units at the same time, not just one at the time.
| | | | | | · | Support for D11-50”/65”, D10-103”, and re-introducing support for D7-37”.
| | | · | Support for CimC3x 1080 projector.
| | | | | | · | New set-top box standby options: OFF AT SOURCE CHANGE: Use this setting for set-top boxes that start up quickly or are noisy when running. OFF AT TV STANDBY: Use this setting for set-top boxes that are slow at starting up. ALWAYS ON: Use this setting for set-top boxes that are slow at starting up and often used. MANUAL CONTROL: Use this setting for set-top boxes that you want to control, or if power ON/OFF is not possible (the television does not try to switch the box on or off). Some set-top boxes has the on/off function implemented via Beo4 meaning that GO + 0 sends an on/off command, but this does not apply to all boxes.
| | | | | | · | Support for multiple PC sources (for future use).
There are a number of remaining errors that will be fixed in the next release, so there could another thread as you indicated above...
Roger |
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Does anyone know that the all-important 'crash to off' issue is fixed? I'm going to wait for some feedback before asking my dealer to install sw 5. I don't think they'll take too kindly to having to install more sw in the future.
Weebyx
- Denmark
- Posts 321
moxxey:Does anyone know that the all-important 'crash to off' issue is fixed? I'm going to wait for some feedback before asking my dealer to install sw 5. I don't think they'll take too kindly to having to install more sw in the future.
Well, i haven't had a crash with 4.95 since the 15'th, so i believe this feature is resolved. /Weebyx
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Roger: These are the new features | | | | | | · | Extended “sense” – senses changes on all video signals from peripheral units at the same time, not just one at the time.
What is the benefit of extended sense, what does it do?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
BMGHB
- Posts 219
It is fixed. But there is coming a SW 5.1 late this week or early next week.. It should fix something with projectors i have heard.. The main fix for the BV7-40MKIII,BV9 is SW 5.0 and it is available now..
Beolab
- Sweden
- Posts 535
Technical information HDMI source makes TV switch off, PUC sync. fault, STB switches off, HDMI sound problems - update to software version 5.00 Build 431 Information valid for: BeoSystem 3, BeoVision 7 - 40 MK III, BeoVision 9 - 50, BeoVision 9 - 50 MK II, BeoVision 9 - 50 MK III Regards
Seanie_230
- Posts 962
can you please explain i have been told there is a "war and peace" document explaining how to install the update and register each HDMI sourse once at a time and turnign off and on the TV is this correct and will this have to be done every time i add a new device Do you have a copy of the document?
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
If I understood you well (english is not my first language and you don't help me not using dots and commas), is better to update your system step by step. There are some modules that must be update. I do it unplugging the TV after each update for more than 45 seconds. You have to start updating H8, and then, you can follow updating each module, but, as I said before, unplugging the TV after each update. I don't unplug the TV after add a new device, even if it is connected via HDMI. I hope it helps.
Beolab
- Sweden
- Posts 535
seanklemis:can you please explain i have been told there is a "war and peace" document explaining how to install the update and register each HDMI sourse once at a time and turnign off and on the TV is this correct and will this have to be done every time i add a new device Do you have a copy of the document?
This is what you are searching for...: Update software to H8 SW 5.00.
IMPORTANT! After updating the software, you must enter the CONNECTION menu and go through the "standby options" for all connected set-top boxes to determine which setting suits the box best (see above). When settings are made for all set-top boxes, leave the television on (the source must be TV, even if there is no signal) and switch all connected set-top boxes on and then off one by one. This teaches the television how the video signal changes with each box.
Regards
Weebyx
- Denmark
- Posts 321
Beolab: seanklemis:can you please explain i have been told there is a "war and peace" document explaining how to install the update and register each HDMI sourse once at a time and turnign off and on the TV is this correct and will this have to be done every time i add a new device Do you have a copy of the document?
Regards
Hmm, this i guess, is only for SCART connected boxes, since HDMI doesn't have any way of knowing if the box is on or off ? But what do they mean by switch on-off, is this via the STB of via the box with the original remote ? P.S i have never had any problems with SCART stb-boxes, only HDMI, so i guess this is'nt for me?
/Weebyx
moxxey
- South West, UK
- Posts 2,360
Ok, my BV7-40 MKIII was upgraded to sw 5.00a this afternoon. All seems fine so far. I'll report back on the crash-to-off later in the week (that's the number one fix for this sw). I expect it's fixed though.
Beolab
- Sweden
- Posts 535
Weebyx: Beolab: seanklemis: can you please explain i have been told there is a "war and peace" document explaining how to install the update and register each HDMI sourse once at a time and turnign off and on the TV is this correct and will this have to be done every time i add a new device Do you have a copy of the document?
Regards
/Weebyx
This is a new feature for set top boxes.. When updating the TV with sw5.0 the TV most learn to sense the specific On and Off signals from the box connected via the HDMI input.
moxxey
- South West, UK
- Posts 2,360
Major problem: I'm constantly getting a Sky warning that 'this display does not support HDCP' after the new sw update. Screen goes blue with the warning. WTF? This keeps happening every 2 minutes. I've tried turning off the Sky box, shutting down at the mains and everything? Any ideas?
Seanie_230
- Posts 962
just a thought what resolution do you have the sky box set to ???? they must have tested this in house and beta testers woudl have noticed
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
moxxey:Major problem: I'm constantly getting a Sky warning that 'this display does not support HDCP' after the new sw update. Screen goes blue with the warning. WTF? This keeps happening every 2 minutes. I've tried turning off the Sky box, shutting down at the mains and everything? Any ideas?
Not sure exactly what the issue is here, but as a quick-fix/workaround to get it working in the meantime, I would connect the Sky HD box via Component if your box has it. The latest Sky HD boxes don't and I can't remember off the top of my head how old your box is!
Weekly top artists:
moxxey
- South West, UK
- Posts 2,360
seanklemis:just a thought what resolution do you have the sky box set to ???? they must have tested this in house and beta testers woudl have noticed
It's set to 1080i. Nothing has changed apart from the sw update. I'm doing some more tests. This is really weird - it only seems to happen when the link TV is on. If I just watch via the BV7, it's fine!
