1st March February 2012
Latest post 02-12-2009 11:43 AM by Quim43. 387 replies.
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
Re: BV7 40 MKIII / SW 4.24 problem
moxxey:Beolab, this is the version we all have installed and is the reason behind the thread. Apparently there is a new sw (need to speak to my dealer on Monday) which is being tested internally, which was offered to me by my dealer when I was away.
Yes i know, but not all people/dealers now that you need to install the H8 software separately! It´s not updated if your dealer only update the software to 4.24a! The dealer / service guy most update this manually in the Service Tool MK II.
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
i heard from my dealer on friday and he says there is a download 5.xx and he says he has downloaded it, a manual update he said im going to find out monday when he will install
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
martin01
- Joined on 04-17-2007
- Sweden
- Posts 207
I have also yesterday my first "crash" with my BV7-40 MarkIII. I have had the sw 4.24 installed in july. Does anyone know anything about a new software yet? Regards Martin
Beolab 5 with sw 3.0, BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
Seanie_230
- Posts 962
i have been told that there was a fix in version 5.24 and now 5.26 is availible according to my dealer and it shoudl be installed on my TV in the next few days the lack of info it annoying though call your dealer and tell him you want 5.26 install on your tv ASAP according to B&o technical Uk this fixes the problem
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
I wonder how they figure their revision references? ie. the jump from a v4.xx to a v5.xx should be 'significant'. If not, they ought to progress through 4.3x, 4.4x, 4.5x etc.
Seanie_230
- Posts 962
hi moxxxey i did ask my dealer this and he said that there is normaly a software update every few days that fix things and work on other things but we dont notice as we dont need them all i know is im told 5.24 contains the fix for the problems we have been having and i am going to get 5.26 installed. I hope this happens as i am getting sick of hearing its fixed and then looking silly when i annoce it on here
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
Please note that sw 4.24a is the 'current' release for BeoSystem 3. Software 5.2.4, 5.2.5 and 5.2.6 are versions for the Service Tool (mk2) - and that 5.2.5 never was released and 5.2.6 was released September 18th. Most here are looking for a fix for BeoSystem 3, and not the Service Tool itself. Roger
Seanie_230
- Posts 962
i dont know i am geting sick of the lack of info provided, i was told by my dealer that the technical guys have said that its fixed who am i to argue? i have just called my dealer and said i am annoyed with the mix match of info i am getting and he started up his laptop and read me the release notes that come down with the newest service tool. currently 5.34
Service tool mk 2 realase notes 5.23 - correction for bv-7-40 mk3 beosystem 3 5.24 - correction to bv7-40 mk3 beosystem 3 5.26 - correct to BV4 (no idea about what this fixes)
i am waiting for this to be installed then i will know more but as i say im only going on the info i am being given
Roger
- Norway
- Posts 870
But these corrections are for the Service Tool Mark II - to make it work smoother. To add to the info you provided: ServiceTool MK2. |
span.TextColor7 { color:#0000FF; }
span.DefaultParagraphFont { }
div.BodyText { font-family:'Verdana'; font-size:9pt; }
div.Normal { font-family:'Times New Roman'; font-size:10pt; }
table.TableNormal { }
ins {color:blue}
del {color:red}The Bang & Olufsen ServiceTool MK II has been updated to version 0.5.2.6. (18.09.2008). Use the “Update application” button in the lower right corner of the ServiceTool to update via server connection. A brief outline of the changes is given below: Service Tool MKII version 0.5.2.6 | | | | · | PUC table update for BeoSystem 3, BeoVision 4, BeoVision 7 and BeoVision 9 |
| | | | · | Improved tips/instructions for BeoVision 4 ACM | | · | Added decoder (remember to update additional files) |
Service Tool MKII version 0.5.2.5 (Not released) Service Tool MKII version 0.5.2.4 | | | | · | BeoVision 8-26/32 software build 109 (can only be added on build 77/37) |
| | | | · | Correction for: Manual software update fails for BeoSystem 3, BeoVision 7-40 MK III |
| | | | · | Small HDR2 and W1 tool improvements |
Service Tool MKII version 0.5.2.3 | | | | · | Correction for: Automatic software update fails for BeoSystem 3, BeoVision 7-40 MK III |
This is something totally different than the BeoSystem 3 software updates - the release info on sw 4.24a for the BeoSystem 3 is: White flash, picture Format changes, CD muted too long, stand problem - software update to version 4.24a |
span.TextColor1 { color:#000000; }
span.Hyperlink { color:#0000FF; text-decoration:underline; }
span.TextEmph2 { color:#000000; font-weight:bold; }
div.Heading1 { margin-top:12pt; margin-bottom:15pt; font-family:'Verdana'; font-size:11pt; font-weight:bold; }
div.TablePadding { margin-top:0pt; margin-bottom:0pt; font-family:'Verdana'; font-size:6pt; }
div.TableHeading { font-family:'Verdana'; font-size:9pt; font-weight:bold; }
div.TableText { font-family:'Verdana'; font-size:9pt; }
div.cell_4cb2ed92 { font-family:'Times New Roman'; font-size:10pt; }
td.cell_baa19589 { border-left:solid #808080 0.5pt; border-top:solid #808080 0.5pt; padding-left:0pt; padding-top:0pt; padding-right:0pt; padding-bottom:0pt; }
td.cell_418a957e { border-left:solid #808080 0.5pt; border-top:solid #808080 0.5pt; border-right:solid #808080 0.5pt; padding-left:0pt; padding-top:0pt; padding-right:0pt; padding-bottom:0pt; }
td.cell_bc34dcc8 { border-left:solid #808080 0.5pt; border-top:solid #808080 0.5pt; border-bottom:solid #808080 0.5pt; padding-left:0pt; padding-top:0pt; padding-right:0pt; padding-bottom:0pt; }
td.cell_2cc23e49 { border-left:solid #808080 0.5pt; border-top:solid #808080 0.5pt; border-right:solid #808080 0.5pt; border-bottom:solid #808080 0.5pt; padding-left:0pt; padding-top:0pt; padding-right:0pt; padding-bottom:0pt; }
ins {color:blue}
del {color:red}New Features Support for 24p (24 pictures per second) video signal via HDMI. Symptom | | | | 1. | White flash at the bottom left-hand side of the TV screen on with HDMI sources. | | 2. | Picture Format changes in main room when sound from TV is selected in link room. | | 3. | CD is muted too long when starting up from standby. | | 4. | Format change not possible after Radio source, if viewing a 16:9 transmission. | | 5. | STB-C sends digits too fast, HDR records wrong channel. | | 6. | Product does not start up when Sony STB I is connected (only reported from Japan, solved in software version 4.17). | | 7. | Short blue picture when switching from cinema mode to TV-viewing mode. | | 8. | Stand will not turn left after mains reset. | | 9. | Inverted colours and flashing picture after pressing ‘FORMAT’ + ‘GO’ (only seen with very few STB-C’s and a few BeoSystem 3). | | 10. | Tearing problem with PS3 (Blu-Ray player) connected via HDMI, only in Format 2. | | 11. | Bang & Olufsen teletext language/character set is 'reset' to zero when changing source or switching to standby. | | 12. | The indicator light remains green after switching to standby. | | 13. | Spelling error in German in the Timer Programming menu. | | 14. | Sound volume increases while switching to standby after radio and TV source, if the stand has to turn much. | | 15. | Curtain is not present when switching on the source ‘DTV’. | | 16. | DVB-T/S picture freezes intermittently. The signal indicator shows good quality and high signal level. The symptom is only seen on 'TV Barcelona' and only occurs with DVF software version 1.50. |
Roger
Seanie_230
- Posts 962
do you think that the problem might not be 4.24 but a problem with the flashing of the software ie a problem with the service tool causing 4.24 to not be installed properly as i hear there are loads of peopel with my set up and only a few people are getting the problems, so maybe the service tool problem causes the whole issue.
BMGHB
- Joined on 05-12-2007
- Posts 219
Do you have the factory installed PUC list or did the dealer create and flash a list for you ?
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
Seanie_230
- Posts 962
i have the default list i know they install one and it did nto have sky as i believe it was european and then flashed again with the version that contains the puc for SKY HD
Seanie_230
- Posts 962
ok my TV is being updated tommorow with the new software and using the new Service tool. i will post all stats after 1030am GMT once the update has been done and then we can begin to see if the update has fixed the issue with the STB acting very strange and the TV crashing randomly. Looking forward to it working "finers crossed"
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
seanklemis: ok my TV is being updated tommorow with the new software and using the new Service tool. i will post all stats after 1030am GMT once the update has been done and then we can begin to see if the update has fixed the issue with the STB acting very strange and the TV crashing randomly. Looking forward to it working "finers crossed"
Well, since i bought a BV4 instead of the BV7, i have not had the tv crash once, and the BS3 is also running 4.24a, so it is very strange what happens with the BV7 and 4.24a, i hope the best for you. /Weebyx
martin01
- Sweden
- Posts 207
My BV7-40 MarkIII "crashed" yesterday again. I went in the Service menu and checked what error code it was when it crashed. It said "Watchdog reset". Does anybody of you know what this is?
Seanie_230
- Posts 962
i have B&o here right now and the software is being flashes with service tool MK2 5.2.6 and it fails half way through, error ~1320 com port not open yet in the avs - pef module we are now trying again
Seanie_230
- Posts 962
on the second attempt the fails above did nto happen and its still going
BEOKNOW
- Joined on 09-11-2008
- Posts 59
The software fix is NOT available yet...SW 5.00 will be available very soon (this month) and willl fix a lot of problems, I believe the switching off when using a third party product connected via HDMI should be one of the fixes...
Seanie_230
- Posts 962
ok software update has completed with no errors this time all the way through no the waiting game, i have removed teh scart lead and wil see if it crashes
Seanie_230
- Posts 962
BEOKNOW:The software fix is NOT available yet...SW 5.00 will be available very soon (this month) and willl fix a lot of problems, I believe the switching off when using a third party product connected via HDMI should be one of the fixes...
i have been told different by my dealer and his info comes from technical UK. who knows i still have 4.24a build 344 i believe and the only thing i can do it wait and see if what they say will fix the problem will actually fix the problem.
Seanie_230
- Posts 962
well it has 4.24a on it and without the scart lead the HD box is not turning off and on the HD box and loosing Sync already.
BEOKNOW
- Posts 59
When using Sky HD connected via HDMI you most connect a skart lead also for control purposes. Software 5.00 WILL be available very soon - believe me!
Seanie_230
- Posts 962
is this always going to be the case that a scart lead will need to be conencted for a HD box using HDMI connection???
