Latest post 03-04-2008 11:42 AM by Bouncer. 86 replies.
Page 3 of 4 (87 items) < Previous 1 2 3 4 Next >
  • 10-24-2007 9:50 AM In reply to
    Re: HDMI EXPANDER FOR BV7
    Perhaps a silly question, so please excuse my ignorance.
    If this HDMI Expander is used on a e.g. BeoVision 7 or BeoCenter 6 and e.g. an HD box is connected via an HDMI cable, can this source then be viewed in a link room?
    I know the source can be viewed in a link room if the HD box is connected via scart, but what if it is connected via HDMI through this HDMI Expander (or any other DVI->HDMI converter)?
    I think the HDMI Expander is the extension I need, but I have no use of it if it means that I cannot view the connected sources in my link rooms.
    BR,
    Lars.
  • 10-24-2007 10:44 AM In reply to
    You'll probably have to connect both the Scart AND the HDMI from the STB to the BV7.
    I have not read the expander would work with BV6, can someone confirm?
     DVI does not carry sound, so the Scart connection is probably compulsory anyway.
     p.
  • 10-24-2007 12:35 PM In reply to
    Ok Guys... Enough tech talk....
     For a beginner like me some easy questions....
    1)  I have the MKII... Can it actually be upgraded to show full HD on the current LCD ?
    2) How do I go to the service menu... Would like to test my movie option....
     The Dane : -)
    Maybe this is as good as it gets... BV7-40 MKII, BL9, BC2, BL6000, MX4000, Beosound 3, HDR1
  • 10-24-2007 2:32 PM In reply to
    Post for future reference.
    Filed under: , ,
  • 10-25-2007 2:59 PM In reply to
    .... Nothing ??
  • 10-26-2007 6:31 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    I have been told today that Bang & olufsen are not goign to supply this unit now.
    Also i pose a question, if the expander switches between hdmi 1-4, where does the stereo sound come from as dvi does not use sound. so if for example you have a sky box you need to use HDMI for picture, optical for Dobly and then also scart for stereo sound.
    this solution is not sounding such a good idea now.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 10-26-2007 7:19 AM In reply to
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    I hope this isn't the final decsion from B&O as I believe this product is needed to make the BV7 'more future proof'.
    Having to have SCART, HDMI and Digitial Coax connected for COAX is no different to how it is connected now.  Does this come down to PCM again?
    Greg
  • 10-26-2007 7:22 AM In reply to
    • GSHaigh
    • North West UK
    • Posts 163
    Having to have SCART, HDMI and Digitial Coax connected for Sound is no different to how it is connected now.  Does this come down to PCM again?
    Greg
  • 10-26-2007 10:44 AM In reply to
    B&O is recommending a specified 3rd party hardware and has released software chip for beo4 integration-requires engineer installation.
    More details later
    Vince
  • 10-26-2007 11:28 AM In reply to
    • GSHaigh
    • North West UK
    • Posts 163
    Presumably something along the lines of this....
    http://www.octavainc.com/HDMI%20switch%204port_toslink.htm
    But with IR support from the BV7?
    Greg
  • 10-26-2007 1:09 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Oh vince what info do you have, how will the sound leave the hdmi and go to the TV
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 10-26-2007 6:09 PM In reply to
    Is the expander the only way to upgrade a BV7 40 mark ii to mark iii?
  • 10-27-2007 3:02 PM In reply to
    The 3rd party hardware are Gefen 4:1 switch and Gefen 1:2 splitter and the guide post in this thread should be used to register HDMI expander. Had a quick look on internet and they arenn't cheap. TV software should be 7.7 or higher. May get installer to sort this out!
    Vince
  • 10-28-2007 5:14 AM In reply to
    Sounds great, but what about the sound???
  • 10-29-2007 4:08 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    hi there buddy no one knows about sound yet i dont think unless we have to use a scart lead stil., i think this thing is a bit of a pie in the sky idea at the mo.
    no one really knows anything and Bang & Olufsen do there normal trick of saying nothing.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 10-29-2007 2:26 PM In reply to
    Ok Guys... I'll try once again
     The Dane : -)
  • 10-29-2007 3:24 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Germany
    • Posts 523
    Niveau:
    Unless already mounted you need a new scaler board and software, both included in the
    HD-ready kit, Type 4370, part no. 1437000
    Niveau:
    MENU 0 0 Go
  • 10-29-2007 3:26 PM In reply to
    Thanks. I believe it's already mounted in my MKII. (Dealer told me) How can I test if so ?
  • 10-29-2007 3:34 PM In reply to
    Niveau:
     The Dane : -)
    It's not posssible to make a HD screen to a full HD...
    set makør på "øvrige muligheder" og tryk Rød Rød + GO...
  • 10-29-2007 4:31 PM In reply to
    So... I have to get the MKIII to watch 1080i ?
    Is it worth it ?
  • 10-29-2007 6:09 PM In reply to
    is it a 32" or 40"?
  • 10-30-2007 2:36 PM In reply to
    It's the 40 inch MKII (I'm sitting 3.5 meters from the screen)
  • 11-01-2007 4:59 PM In reply to
    What's the final judge Stig ?
     The Dane
  • 11-01-2007 6:05 PM In reply to
    Minimum viewing distance for a 40" screen is (distance where the eye can't see a difference/pixel any more):
    SD: 3m
    HD: 2,5m
    Full HD 1,6m
  • 11-02-2007 4:03 PM In reply to
    So..... Final judge is that it cant be worth upgrading !!!
