1st March February 2012
Latest post 03-04-2008 11:42 AM by Bouncer. 86 replies.
Kellogg
- Joined on 09-21-2007
- Posts 52
Re: HDMI EXPANDER FOR BV7
Perhaps a silly question, so please excuse my ignorance. If this HDMI Expander is used on a e.g. BeoVision 7 or BeoCenter 6 and e.g. an HD box is connected via an HDMI cable, can this source then be viewed in a link room? I know the source can be viewed in a link room if the HD box is connected via scart, but what if it is connected via HDMI through this HDMI Expander (or any other DVI->HDMI converter)? I think the HDMI Expander is the extension I need, but I have no use of it if it means that I cannot view the connected sources in my link rooms. BR, Lars.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
You'll probably have to connect both the Scart AND the HDMI from the STB to the BV7. I have not read the expander would work with BV6, can someone confirm? DVI does not carry sound, so the Scart connection is probably compulsory anyway. p.
Niveau
- Joined on 09-25-2007
- Posts 63
Ok Guys... Enough tech talk.... For a beginner like me some easy questions.... 1) I have the MKII... Can it actually be upgraded to show full HD on the current LCD ? 2) How do I go to the service menu... Would like to test my movie option.... The Dane : -)
Maybe this is as good as it gets...
BV7-40 MKII, BL9, BC2, BL6000, MX4000, Beosound 3, HDR1
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
I have been told today that Bang & olufsen are not goign to supply this unit now. Also i pose a question, if the expander switches between hdmi 1-4, where does the stereo sound come from as dvi does not use sound. so if for example you have a sky box you need to use HDMI for picture, optical for Dobly and then also scart for stereo sound. this solution is not sounding such a good idea now.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
GSHaigh
- North West UK
- Posts 163
I hope this isn't the final decsion from B&O as I believe this product is needed to make the BV7 'more future proof'. Having to have SCART, HDMI and Digitial Coax connected for COAX is no different to how it is connected now. Does this come down to PCM again? Greg
GSHaigh
- North West UK
- Posts 163
I hope this isn't the final decsion from B&O as I believe this product is needed to make the BV7 'more future proof'. Having to have SCART, HDMI and Digitial Coax connected for Sound is no different to how it is connected now. Does this come down to PCM again? Greg
vlohjr1
- Joined on 06-26-2007
- Posts 106
B&O is recommending a specified 3rd party hardware and has released software chip for beo4 integration-requires engineer installation. More details later Vince
Seanie_230
- Posts 962
Oh vince what info do you have, how will the sound leave the hdmi and go to the TV
thorne
- Joined on 05-12-2007
- Posts 100
Is the expander the only way to upgrade a BV7 40 mark ii to mark iii?
vlohjr1
- Posts 106
The 3rd party hardware are Gefen 4:1 switch and Gefen 1:2 splitter and the guide post in this thread should be used to register HDMI expander. Had a quick look on internet and they arenn't cheap. TV software should be 7.7 or higher. May get installer to sort this out! Vince
MichaelF
- Joined on 10-04-2007
- Posts 30
Sounds great, but what about the sound???
Seanie_230
- Posts 962
hi there buddy no one knows about sound yet i dont think unless we have to use a scart lead stil., i think this thing is a bit of a pie in the sky idea at the mo. no one really knows anything and Bang & Olufsen do there normal trick of saying nothing.
Niveau
- Posts 63
Ok Guys... I'll try once again For a beginner like me some easy questions.... 1) I have the MKII... Can it actually be upgraded to show full HD on the current LCD ? 2) How do I go to the service menu... Would like to test my movie option.... The Dane : -)
Gerd
- Germany
- Posts 523
Niveau: I have the MKII... Can it actually be upgraded to show full HD on the current LCD ?
Unless already mounted you need a new scaler board and software, both included in the HD-ready kit, Type 4370, part no. 1437000 Niveau: How do I go to the service menu... Would like to test my movie option
MENU 0 0 Go
Niveau
- Posts 63
Thanks. I believe it's already mounted in my MKII. (Dealer told me) How can I test if so ?
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Niveau: Ok Guys... I'll try once again For a beginner like me some easy questions.... 1) I have the MKII... Can it actually be upgraded to show full HD on the current LCD ? 2) How do I go to the service menu... Would like to test my movie option.... The Dane : -)
It's not posssible to make a HD screen to a full HD... set makør på "øvrige muligheder" og tryk Rød Rød + GO...
Niveau
- Posts 63
So... I have to get the MKIII to watch 1080i ? Is it worth it ?
Niveau
- Posts 63
It's the 40 inch MKII (I'm sitting 3.5 meters from the screen)
Niveau
- Posts 63
What's the final judge Stig ? The Dane
The Stig - ver. 1.7
- Posts 898
Minimum viewing distance for a 40" screen is (distance where the eye can't see a difference/pixel any more): SD: 3m HD: 2,5m Full HD 1,6m
Niveau
- Posts 63
So..... Final judge is that it cant be worth upgrading !!!
