        1st March February 2012
	    Latest post 03-04-2008 11:42 AM by Bouncer . 86 replies.
								    |  10-13-2007 6:05 PM |  |
									                 vlohjr1Joined on 06-26-2007Posts 106 |
										    Re: HDMI EXPANDER FOR BV7
										    Would appreciate any further details; is it a separate box and how is it mounted and how much is it?   thanksVince
									                 PhilLondonJoined on 04-16-2007LondonPosts 2,545 |
										    ...and do you need to upgrade the firmware of the tv? |  |
									                 The Stig - ver. 1.7Joined on 06-20-2007Posts 898 |
										    Yes TV need SW and firmware upgrade to 7.7 , it's a separate BOX, have to wait to it's in the shops and see haw it can be mounted on the TV.  |  |
										    thanks for info, but DVI is only picture how does sound get converted as well any idea of cost and when is it available as well?  thanksVince
									                 SorenJoined on 05-04-2007Kolding DenmarkPosts 56 |
										    How can you tell if your 7-32 is MK I II or III   Søren |  |
									                 GSHaighJoined on 04-16-2007North West UKPosts 163 |
										    I really, really, really hope this is true! More details pls! |  |
									                 petrosbeliJoined on 05-04-2007Posts 14 |
										     Soren:How can you tell if your 7-32 is MK I II or III
 From the type number. At least for the MKIII the type number should be between 9331 - 9339.
										     vlohjr1: thanks for info, but DVI is only picture how does sound get converted as well any idea of cost and when is it available as well?  thanksVince
 It's also connected to Digital input A4 where it's controlled from, hope it also use it for Audio  |  |
									                 GerdJoined on 04-20-2007GermanyPosts 523 |
										     GSHaigh:I really, really, really hope this is true! More details pls!
 IT IS - check addition to the guide in attachment. I had to delete the first and last page (cover) in order to reduce the file size to the allowed maximum of 100kb!
										    Thanks Gerd!  Looks a very nice solution. But I don't really understand how audio is handled in this setup... Anyone can explain?
										    Reading the PDF it reads as if it also connects to Audio C4 for control.  Although this isn't shown in the diagram. I've been hoping this product would appear,  so a BIG thank you to B&O!  I guess this means the BV7-32 won't have the BS3 chassis, but who cares!   Now I just need a neat solution to use this in conjunction with BeoMedia and I'll be happy!  At the moment my BeoMedia is connected on DVI and my SKY HD is on component.  Any ideas how I'll get round this? Greg |  |
										    I also don't get the text: "If an HDMI Expander is connected, the audio socket C4 is not available, since the HDMI Expander claims the C4 socket for control.". "audio socket C4"? C4 is not an audio socket but an IR control socket. A4 is for audio... right? So what do they mean? Also, the diagram in the first page shows that the expander is indeed connected to the IR socket...   I would think that the phrase "audio socket C4" should "IR control socket C4". Only then it would make sense... Petros
										     petrosbeli: I also don't get the text: "If an HDMI Expander is connected, the audio socket C4 is not available, since the HDMI Expander claims the C4 socket for control.". "audio socket C4"? C4 is not an audio socket but an IR control socket. A4 is for audio... right? So what do they mean? Also, the diagram in the first page shows that the expander is indeed connected to the IR socket...
 You have a point there  it makes more sense to connect it to C4 as it's an output.. |  |
										     petrosbeli:I also don't get the text: "If an HDMI Expander is connected, the audio socket C4 is not available, since the HDMI Expander claims the C4 socket for control.". "audio socket C4"? C4 is not an audio socket but an IR control socket. A4 is for audio... right? So what do they mean? Also, the diagram in the first page shows that the expander is indeed connected to the IR socket...   I would think that the phrase "audio socket C4" should actually be "IR control socket C4". Only then it would make sense... Petros
										    where did you get the guide any more pictures?  does anybody does when it isavailable? thanks VInce |  |
									                 moxxeyJoined on 04-14-2007South West, UKPosts 2,360 |
										    Although this a good option, it's definitely not a MKIII replacement - the big difference is the BS3-based chassis and that the DVD upscales the source. The worst thing about my MKI BV7 is that DVDs are so dark and gloomy, they are difficult to watch. The same film through Sky or BBC HD is far brighter, which means it's definitely a DVD player issue.. I hope this HDMI splitter isn't too expensive. I've already paid £350 to upgrade the MKI to HD :) |  |
										    I rang two UK B&O dealers for further info about the splitter in London; and I have unhelpful replies and comments and even some unfriendly and unkind remarks about Beoworld. If there were no Beoworld I would not have known about this-so thank you! Vince |  |
										    Yes, Beoworld seems to generate a love/hate reaction with many dealers. The same applies to Lifestyle AV and so on. The thing is, many dealers have second hand or ex-demo equipment available if you ask, so I don't see why they worry so much. I guess information can be 'evil', so the Internet, eBay, Beoworld and so on generates availability and info that traditional retailers fear.  The thing is, retailers can't stop change and being grumpy or dissing competition isn't going to make them appear in a good light.  |  |
									                 BouncerJoined on 07-07-2007Posts 46 |
										    How do I know which software version I am on and will I be able to carry out the upgrade myself?   Thanks. |  |
										    if your TV is more then a month old it need an SW update, it's not possible to do yourself... |  |
										     moxxey:Yes, Beoworld seems to generate a love/hate reaction with many dealers. The same applies to Lifestyle AV and so on. The thing is, many dealers have second hand or ex-demo equipment available if you ask, so I don't see why they worry so much. I guess information can be 'evil', so the Internet, eBay, Beoworld and so on generates availability and info that traditional retailers fear.  The thing is, retailers can't stop change and being grumpy or dissing competition isn't going to make them appear in a good light.
 Several dealer told me that I would get more money if I sold my TV through Lifestyle than if I sold it myself, and they pointed me to the web site. As for Beoworld, they used to be told by B&O not to participate in the forum. As we know we think B&O has changed their mind, so it will take a bit of time before it gets down to the dealers.  |  |
									                 BeolabJoined on 05-18-2007Sweden Posts 535 |
										     moxxey: Although this a good option, it's definitely not a MKIII replacement - the big difference is the BS3-based chassis and that the DVD upscales the source. The worst thing about my MKI BV7 is that DVDs are so dark and gloomy, they are difficult to watch. The same film through Sky or BBC HD is far brighter, which means it's definitely a DVD player issue.. I hope this HDMI splitter isn't too expensive. I've already paid £350 to upgrade the MKI to HD :)
 It´s because the movie mode is ON when you watch DVD:s. And when you are watching Sky or BBC HD the movie mode are set to OFF. Go in to the service menu and set it from Auto to off. Then the DVD:s should be as bright as Sky HD movies... And you get less motion sickness and less overall artefact's.. Try...   Regards |  |
										    Beolab, I've read these forums long enough to understand all about the movie mode. It's definitely off. I've been off since I bought the TV in 2004 :) Believe me, a DVD through the DVD player is much darker than via Sky HD and that's nothing to do with a 'movie mode'. Backlight is on, I've increased the brightness (in the service menu) as much as possible, contrast etc etc. |  |
										     moxxey: Beolab, I've read these forums long enough to understand all about the movie mode. It's definitely off. I've been off since I bought the TV in 2004 :) Believe me, a DVD through the DVD player is much darker than via Sky HD and that's nothing to do with a 'movie mode'. Backlight is on, I've increased the brightness (in the service menu) as much as possible, contrast etc etc.
 I´m sorry Moxxey, just a first idea that comes up in my mind to solve the problem.  Have you tried to increase the master contrast (Backlight contrast) in the service menu then?   Hm, it must be the DVD or the panel then.. Did they change panel to the MK III panel when you had it in for service?  I don´t remember... Regards |  |
