1st March February 2012
Latest post 11-18-2011 7:44 PM by Todd. 406 replies.
hemenex
- Joined on 04-23-2007
- Posts 375
Re: RL60.2 Refurb Collaboration
elephant: actually 2,000 years old
another oops - and I had 7 years of "big latin" back in school
Anyway, it wasn't my language and I squeaked by with a "D"
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
tournedos:
Umm... I think you should've glued the fabric in the bottom of the grooves as well, as the bands aren't going to pull the fabric into them... they are purely for visual purposes, not for tightening anything. But that'll be a minor problem, I'm sure they'll still look great
I'll admit I wasn't excited to read this. The fabric only sits a few millimeters above the groove, I'm sure the straps would pull the cloth down to the surface, no?
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Evan: I'm sure the straps would pull the cloth down to the surface, no?
Yes
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Evan
- Ohio | USA
- Posts 2,601
hemenex:
Evan: I still find myself thinking about this!
Ok Mr. Evman, then there's no shipping, sorry...
Because then the way to do it is the Struer way - I'm absolutely sure we all want to have your promised birthplace factory story here to read
This alone would be worth givin' the BM4000 away (a functional one though; still leaving the recapping up to you for yet another story )
Gunther
BTW: Did you measure the driver in question de-soldered? You mentioned they are different in the 2 speakers?
As I only have the SM for the previous PL60.2 with the ABR's and yours / Todd's are newer ones the crossovers are different
No need to give up a working 4000, I don't think I could accept that!
BTW, yes, the speakers are wildly different somehow internally. Check out my table a a few pages back. The results are all so weird!
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Yes
Ahhhh, that's relieving to hear!
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
I brought a BS 3000 and 2 BL 4000, as carry on bagage, from DK to Mex, back in 2001 or 2, my wife the BS 3000 in a back pack, and I the BL 4000s in a back pack. All brand new. In Mexico at that time these items was some DKR 50,000.00 (USD 10.000) and in DK I could buy the same for DKR 24.000,00. The dealer sold it for Export and I didn't have to pay the Danish 25% VAT. The dealer even made the 120 V convertion on BLs and BS..
So Evan bring a big back pack to Struer, remember they dont weigh carry on.
And I would like to know what you did or are doing with the diff. driver problems, so back to the bench
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Evan:
Leslie:
Yes
I don't believe it will... to keep this educational, think of some force vectors and how much tension you are willing to put on the strap before it breaks - I'll bet it will bow up in the middle. The groove was glued originally, wasn't it?
But, no problem, just try it first... if it doesn't look good, you can probably still glue through the fabric and push it down with something while the glue dries. The strap will cover the area anyway.
Evan
- Ohio | USA
- Posts 2,601
Søren Mexico:
I am so ready to do this! I already dug out my Swiss Army bag!
First both speakers will be re-analyzed and I will update my table. Todd bought a resister so we could experiment with correcting impedances. I will post the findings. Hopefully Iwill be able to do some SPL/octave measurements and quantify the before and after.
Evan
- Ohio | USA
- Posts 2,601
tournedos:
Evan:
Leslie:
Yes
Yes, the originals were glued. We will try it first and will report back!
hemenex
- Posts 375
Evan: First both speakers will be re-analyzed
Sorry if I repeat myself but is the mid driver really another number or does it just measure different when soldered in?
According to the original B&O specs the 8 Ohms impedance for the complete speaker measured on the leads is the correct one - strange that the "better" one has 4 Ohms only
Key point will be equal drivers on both speakers - I don't think you can compensate with a purely resistive thing in series...
If still in trouble - desolder the mid driver in both units and "swap" them electrically with long wires - will have the same result as changing the driver physically like Martin suggested - then you don't need to "break" them out. Play a mono tune and compare...
And while desoldered measure the resistance of both drivers without any leads to surrounding other parts spoiling the measure. You measure resistance instead of inductance anyway as long as you are using a standard DVM.
A picture of the "red, red, black, brown (or gold? silver?)" thingy would be helpful to decide what it is.
Gunther
P.S. My older RL60 have both 5.4 Ohms in DC.
hemenex
- Posts 375
Ev, now you got me hooked on that...
I had a closer look at your crossover picture before modifying.
And I had another look at the Beovox service manual available on-site (look after Beovox4 manual).
Page 1-15 looks like the crossover of the RL60.2. That board has 5 caps, 3 coils (+ one external) and 2 resistors.
Yours seem to have 4 caps, 4 resistors and 3+1 coils. Strange - has it been modified before?
Also the order number of the 2 "woofer" and "mid" drivers are equal (?) so should be the same (?).
Do you have a picture of the printed side of the crossover? Are both crossovers equally equipped?
Gotta fix that thing...
Evan
- Ohio | USA
- Posts 2,601
Hi Gunther,
Sorry I haven't been able to fully respond to your questions, for the most part I've been posting from my mobile - I always leave out details when posting that way.
I can't fully remember if I measured all 4 woofers unconnected. Which is why I will be taking both speakers back to the work bench to get a new set of uniform readings. Will start that shortly here in a few minutes.
I have also done complete speaker measurements, which are unequal. The good speaker is 4ohms and the problem speaker is 8 ohms.
These crossovers have not been altered in anyway until I changed the caps. Yes, they have the exact same components in the xovers.
I'm hooked on this too, I want to solve this! You are right, the woofers are the determining factor. Give me a few minutes and I'll have an updated set of values for you.
I think it was yesterday I told Todd - "I think this is the most science ever applied to an RL60.2!"
Leslie
- Netherlands
- Posts 2,201
tournedos:
Evan:
Leslie:
Yes
Keep us informed, we both are curious how it works out . But as said at the start of this thread I already mentioned to glue or use DS tape the strap grooves.
Leslie
- Netherlands
- Posts 2,201
What kind of straps are you using Todd&Evan? Did you already had the original ones?
Evan
- Ohio | USA
- Posts 2,601
Okay Gunther, here they are. With the drivers disconnected, for sure!
Component
Factory Spec. (Ohms)
Good Speaker (Ohms)
Bad Speaker (Ohms)
Tweeter
6
4.6-4.7
4.6-4.7
Mid-Woofer
8
6.3-6.4
Open circuit
Woofer
8
6.2-6.4
5.9-6.2
Small Coil
0.8
0.8
Medium Coil
0.5
0.5-0.7
Large Coil
0.7
0.5-0.6
External Coil
1.1
1.1-1.2
6R8 5% > X0
6.8
6.8
6.8
15R 10% > X7
15
14.7
15.1-15.2
Resistor | | | |
22
1.7
1.7
1R0 5%
1
1
1
Speaker (Total)
8
3.8
7.2-7.3
I knew it was the mid-woofer all along...
BTW I'll get the pic of the printed side of the xover for you.
Evan
- Ohio | USA
- Posts 2,601
Leslie: Keep us informed, we both are curious how it works out . But as said at the start of this thread I already mentioned to glue or use DS tape the strap grooves.
Yes I remember. We should have listened. The original straps are broken and gone away. I was going to help Todd track down some reproduction straps. I remember there was a BeoWorld member who was able to supply them at some point.
Leslie
- Netherlands
- Posts 2,201
Evan: I remember there was a BeoWorld member who was able to supply them at some point.
Yes, here excellent quality! I have them!
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Okay, great! Hey Todd, you see this? Get on it!!
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Leslie:
Could that deck be any prettier?!?! Well done, Leslie. How does it sound?
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Rich
- Posts 1,089
Evan:
But you were getting some sound out of it before, right?
Evan
- Ohio | USA
- Posts 2,601
Rich:
Yes, and still do. It actually has a decent output for a woofer that measures open circuit..
Rich
- Posts 1,089
Evan:
Rich:
Well, remember the impedence of a loudspeaker and each of its component drivers varies with the frequency of the input. DC impedence isn't exactly indicative of what the driver will see throughout its frequency range. Of course, one would expect the two drivers to measure the same.
My semi-educated guess is you have a damaged voice coil.
While I've never used Mark for this service, Meniscus Audio offers reconing service for damaged voice coils.
Image source: http://sound.westhost.com/lr-passive.htm
Evan
- Ohio | USA
- Posts 2,601
Here you are Gunther, sorry it took so long, I was distracted by dinner!
Eugene
- Joined on 12-17-2008
- Posts 589
The were several "changes" or slight redesigns to the 60.2 crossover during production. The cross you are flashing Evan looks like mine but if Mika come thru with a picture of his it will be a chunk of chip board with everything run in series (like an old uniphase cross) It was changed at least one more time with the RL6000 and it nothing close electronically to the RL60.
The Service manual as I recall had a couple typos and emissions which is why I usually dont order parts until I have had a look inside.
Your lucky if the driver is bad I have a spare. In fact I have a whole speaker munus the cabinet.
Evan
- Ohio | USA
- Posts 2,601
Rich: Of course, one would expect the two drivers to measure the same.
Exactly. For me to get equal performance I need drivers with equal electical properties.
If I had one driver rebuilt, would it still result in a unbalanced pair? Would Todd have to get both mid-woofers rebuilt to get the all-desired balance between the speakers?
