1st March February 2012
Latest post 02-12-2009 11:43 AM by Quim43. 387 replies.
timhanna
- Joined on 11-28-2007
- London
- Posts 602
Re: BV7 40 MKIII / SW 4.24 problem
woohoo, i got my tv a month ago, do you guys think that i can get this fixed under warrenty?
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
if you did not get it fixed under warentee i woudl ask for my money back. the tv u bought if its broken it should be fixed free mine is broke and its 3 months old and they will come and fix it ASAP with the new software.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
timhanna
- London
- Posts 602
true... ill also ask them to update the STB while theyre here. thanks
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
seanklemis:hi all i have info that the "fixed" version of 4.24 has been released!
Hi, where do you have the info from ?, My dealer couldt see anything on the intranet 5 hours ago ? /Weebyx
BEOKNOW
- Joined on 09-11-2008
- Posts 59
The Service Tool Mk2 has had a software upgrade, but there is no update of 4.24sw at present...
Seanie_230
- Posts 962
im told by my dealer that the service tool upgrade has fixed the problem, im only going on what they told me, according to B&o techinal UK.
Seanie_230
- Posts 962
has anyone else had this confirmed yet by there dealer or has anyone had the new software installed yet?
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Haven't we already covered ground on this 'fixed' sw 4.24? Someone one here installed it and it made no difference. It wasn't a new sw update, just a fix for installing the new sw update. I'm sure it was a mod on this forum. I think we'll need to wait until sw 4.25 or higher for a fix (if a fix is even intended!).
BMGHB
- Joined on 05-12-2007
- Posts 219
Its a default PUC SW. If your dealer installs again it will work proberly im sure. I tried it a few times. And after installing the SW again its works Henrik BTW This is response to the post where the PUC menu didnt appear when pressing menu when in STB/DTV mode.
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
Peter Pan
- Joined on 04-16-2007
- Danmark
- Posts 741
Hello Henrik . I tried tell them that on page 2, but they will not hear. . Håber butikken køre, selv om jeg ikke holder dig i hånden :-). . / Peter Pan
Weebyx
- Denmark
- Posts 321
Peter Pan:Hello Henrik . I tried tell them that on page 2, but they will not hear. . Håber butikken køre, selv om jeg ikke holder dig i hånden :-). . / Peter Pan
It is NOT the same issue we are talking about. The SW 4.24 and the latest update to the service tool is NOT related. The crash-to-off feature is not resolved in any of the service tool updates, it is a SW 4.24 issue, and since my dealer downgraded my tv to 4.17, the tv hasn't chrashed once ! /Weebyx
Peter Pan
- Danmark
- Posts 741
Weebyx you have a private post. / Peter Pan
tobeyone
- England
- Posts 54
New BV7-40 with 4.24a installed this morning.....no problems so far!!
Doc
- Joined on 04-17-2007
- Posts 585
tobeyone:New BV7-40 with 4.24a installed this morning.....no problems so far!!
Tobeyone, Did you buy your BV7 recently? If so, why haven't you waited for a mk4 with 100Hz and/or BlueRay?
tobeyone
- England
- Posts 54
hmmmm....warranty replacement!!
Seanie_230
- Posts 962
mine was fine for the first few weeks then developed the problem
Seanie_230
- Posts 962
Hi all software 4.26 was released on Monday according to B&o techincal. This is supposed to fix many problems with 4.24.
BMGHB
- Posts 219
according to B&o techincal here in denmark has it NOT been released yet. They dont even have a date for its release.
Seanie_230
- Posts 962
well the info i have from technical UK is that its released and ready for download? might be an update for the UK televisions perhaps working with UK set top boxes???? i wonder if thy actually communicate with each other
moxxey
- South West, UK
- Posts 2,360
I've just back from a holiday and was called, whilst away, by my dealer asking if I want to 'test the new sw'. I don't think it's an official release, as B&O UK are/were looking for people to test the new sw to see if it fixes their issue. I don't have it installed, clearly as I've been away.
Seanie_230
- Posts 962
hi moxxey r u going to use it?
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
as of 20:40 EST (GMT -5) no new software available in the US, according to my local shop. OK I watched the updater run on the lap-top. No joy yet!
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
I did an update of my BV-7 Mk3 and installed the software version 4.24a. Everything was ok and the TV works fine till now, but I have a doubt: in the current version of DVF Module Software the Service Tool says I have a GB model, and I am in Spain (I think I should have the EU Model). Does anybody know what DVF Module means? Thanks
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
| Version 424. Release date 16-06-2008 |
Symptom: Support for 24p. White flash at the bottom left-hand
side, Picture Format changes when TV sound is selected, CD is muted too long,
STB-C sends digits too fast, Stand will not turn, Tearing problem with
PS3 / 24p. |
Solution: Update H8 software to version 4.24a (build 344) or
higher. |
moxxey
- South West, UK
- Posts 2,360
Beolab, this is the version we all have installed and is the reason behind the thread. Apparently there is a new sw (need to speak to my dealer on Monday) which is being tested internally, which was offered to me by my dealer when I was away.
