Hi again mate, ill just give the automatic one a test run, it's from Maplins so easy money back if don't work. Obviously this is to automatically control/switch between 2 inputs. It might even have a switch on it so wouldnt be any hardship flicking it on everytime i go to bed to watch tv.
Another question now, I have one Sky HD box in the front room and need a splitter or automatic switcher for that too so i can run a HDMI into the Beovision 8 in the bedroom (only 1 output on these damn boxes!). In effect this is an output situation as opposed to input. Was just gonna get a splitter for this so i don't have to mess about with a switcher as the tv in the front room is a 50 inch Pioneer 508D plasma and the accessability is restricted due to size of system where as it's not a hassle to just reach behind the Beovision 8. Also would i loose picture quality if i get a splitter rather than a switcher and would the same unit mentioned before do the job?
Just to throw another spanner in the works, are these sort of devices bi-directional? For example some splitters/switchers are designed to give more outputs and others more inputs?
Both links included below take a look peeps:
http://www.maplin.co.uk/Module.aspx?ModuleNo=220674&C=Maplin&U=SearchTop&T=hdmi%20splitter&doy=11m4
http://cgi.ebay.co.uk/HDMI-to-2-HDMI-M-F-Video-Audio-Y-Splitter-Adapter-Cable_W0QQitemZ180231917746QQihZ008QQcategoryZ61395QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this makes sense!
 Roger:I have never tried one of the automatic ones, but someone around here at BeoWorld must have? The DVD-player should adjust the output to 720p when connected to BV8 automatically.
Roger
