Latest post 11-18-2011 7:44 PM by Todd. 406 replies.
Page 3 of 17 (407 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 09-01-2011 10:52 PM In reply to
    Re: RL60.2 Refurb Collaboration
    Evan:
    Just made an interesting discovery, although I shouldn't be hugely suprised considering my above data, the speakers overall impedance is vastly different.
    Factory Spec:   8 ohm
    Good Speaker: 3.7-3.8 ohm
    Bad Speaker:   7.8 ohm
    Anyone want to start a brainstorm?
    Are you sure both drivers are equal ??, seams like a 4 ohm and a 8 ohm.
    You should have +- 8 ohms on both, so something is wrong on the one called the "good" driver. measure again (directly on the terminals both should be the same +-) and while playing check with a finger on each cone if the vibration is the same, sound set to mono, or put in a 4 +- ohm resistor on in line to the "good" driver and listen again.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-01-2011 11:48 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    No the drivers are not equal.
    The measurements you quoted there are not just the mid-woofers, but the entire speaker! I measured many times to verify and my numbers are accurate. Have a look at the table a few posts further up.
    I've been thinking of adding in a resistor..
    How could it change so much? What could have changed in the woofer(s)?
    I think I'm going to have to sleep on it! Plus its late!! Sleep
    Evan
  • 09-02-2011 12:13 AM In reply to
    • Todd
    • Top 500 Contributor
    • Joined on 09-01-2009
    • Columbus Ohio
    • Posts 136
    • Gold Member
    Hey Ev Buddy,
    No need to respond just wanted to say I've been reading w/great interest the latest postHmm
     between you and Soren on the divergence in opinion on yours and his readings.
    this is so educational and I can't wait till tomorrow. of course thanks too you Soren for your contribution.
    Todd
    I need all the learning curve I can get!
    Todd
  • 09-02-2011 1:32 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    If in doubt, try swapping drivers between the good and the bad speaker.
    One at a time and see when things change.
  • 09-02-2011 8:46 AM In reply to
    • Todd
    • Columbus Ohio
    • Posts 136
    • Gold Member
    Hello Martin,
    That sounds plausible but as you know Evan's the expierienced one here; I'm trying too learn so I will point your suggestion out to him if he hasn't already checked for the latest post this morning.
    Thanks,
    Todd
    Todd
  • 09-02-2011 8:50 AM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Todd:
    Hello Martin,
    That sounds plausible but as you know Evan's everyone knows Martin's the expierienced one here; I'm trying too learn so I will point your suggestion out to him if he hasn't already checked for the latest post this morning.
    Thanks,
    Todd
    Fixed that for ya.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-02-2011 9:52 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Dillen:
    I was hoping no one would say that! These woofers (like every other RL), are cemented in place!!
    Evan
  • 09-02-2011 10:28 AM In reply to
    • Todd
    • Columbus Ohio
    • Posts 136
    • Gold Member
    Good Morning All,
    We are about to open up shop and all comments and suggestions are welcomed. Yes if you want to be so brave as to edit my post as Rich on Martins behalf! Jump In the water is a little choppy but warm Smile So Rich I yield to your edit but EvanStick out tongue, well thats anotherStick out tongue issue between Techies that I will have fun watching. So come and lets make it another fun and productive day. Alright Lets Roll!
    Todd
  • 09-02-2011 12:45 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Here is Todd taking off the bezel that keeps the fabric from coming loose.
    Evan
  • 09-02-2011 1:24 PM In reply to
    Evan:
    No, just sitting a little hard with a rubber gasket, pry it out slowly and carefully, prying all around the driver basket, with a wide bladed screwdriver. Reinstalling take care not to pull the screws to hard, and all screws with the same force.
  • 09-02-2011 4:24 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Søren Mexico:
    Evan:
    Thanks Soren. Yes, I know they aren't actually cemented in place. I feel like if I tried this I would end up damaging Todd's beautiful speakers. If it comes down to it, we may have to swap them but for now, he has decided not to.
    Evan
  • 09-02-2011 4:28 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Alright Leslie! Here is the part you were waiting for!! Stick out tongue
    Here are the RLs, freshly skinned.
    Todd, are you holding yours upside down?! Laughing
    Evan
  • 09-02-2011 4:30 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Ok, for now that is all I have time to post. We did make a good deal of progress, but you all will just have to wait and see.
    Todd and I both have to head out for work. I will post the rest tonight!
    Evan
  • 09-02-2011 4:36 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Evan:
    Uncool leaving us hanging.  No - thumbs down
    Get an 8 to 5 job!  (And a turntable while you're at it.)
  • 09-02-2011 5:09 PM In reply to
    Rich:
    What can be more important than a BEO speaker repair, OK boys will wait, but I dont like itBig Smile
  • 09-02-2011 5:30 PM In reply to
    You are fantastic, brotherhood first class! Wish I could stand between you guys. It's great to see members live on pictures. Maybe tomorrow I will show you a picture of me working on my Beocord. It will be a fantastic day tomorrow with lots of sunshine.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-02-2011 5:38 PM In reply to
    Somewhere on one of my hard drives I will have to dig up the photos I took of the process i used to recloth my Red Lines a few years back. 57 days and counting - up,
  • 09-02-2011 5:40 PM In reply to
    Leslie:
    Agree Leslie, these young people give us an example to follow.Yes -  thumbs up
  • 09-02-2011 5:44 PM In reply to
    Eugene:
    Good to see you again, we missed you, and congrats to 57, keep it up, as long as your bike keeps up I dont see a problem.Yes -  thumbs up
  • 09-02-2011 5:45 PM In reply to
    Søren Mexico:
    Leslie:
    Now I (55) feel old Søren but you're right. Beautifull people to look at and with lots of skills....
    And..... Eugene is backDrinks
  • 09-02-2011 5:48 PM In reply to
    If Evan is stupid enough to bring him around me -  Todd's Beotoast. One listen to my rebuilt 4000 on a set of S75's or a look at me rebuilt 2000 or me rebuilt 5000 or my 2400 or my BS3000, CDX, BC 7700... oh nevermind..... !
  • 09-02-2011 5:59 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Eugene:
    Congratulations.  My oldest daughter is now 4 years, 9 months, and 20-odd days, which means it's been 4 years, 9 months, and 20-odd days for me.  Good luck.  I wish I could tell you that it gets easier over time, but it really doesn't.  The psychological and social triggers just never go away.
  • 09-02-2011 6:00 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Eugene:
    He'll have to look at my fixed BG4002 later tonight...
  • 09-02-2011 6:01 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Eugene:
    Beotoast
    Did you just coin a new term?
  • 09-02-2011 7:31 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Rich:
    Evan:
    I work 9-5 tomorrow, any better? As for the turntable - you must be patient! Haha Laughing
    Evan
