Latest post 08-24-2011 8:27 PM by Evan. 85 replies.
Page 3 of 4 (86 items) < Previous 1 2 3 4 Next >
  • 07-26-2011 12:56 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: BeoVox 2500 by Evan
    Rich:
    Evan:
    What ever became of your CX50's? Those would be perfect for ambio.
    Gave them to my mother-in-law.
    Is she an vinyl ambio junkie like you too? Laughing
    Evan
  • 07-26-2011 1:03 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Evan:
    Rich:
    Evan:
    Negative.  But she does dig classic rock.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-26-2011 1:06 PM In reply to
    Rich:
    Evan:
    Rich:
    Evan:
    And maybe she will change the fabric tooLaughing
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 07-26-2011 1:07 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    beocool:
    Thanks for the pictures of your project Evan. Yes -  thumbs up Lots of nice details inside as well. Cool I'm already looking forward to the next one... Big Smile
    No problem! I'm always happy to post these things. The inside was cramped and detail intensive.
    The next one! What would you like to see?!
    Evan
  • 07-26-2011 1:11 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Rich:
    Evan:
    Rich:
    Evan:
    Well I'm sure she will be soon!
    Evan
  • 07-26-2011 1:15 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Now where were we, I have lost my place!
    Evan
    Evan:
    beocool:
    Not sure yet... Have to think about that one. Big Smile
  • 07-26-2011 1:17 PM In reply to
    Evan:
    tournedos:
    I think I would've just let the stand poke through the insides to the opposite corner, that would automatically align the cube as well...
    Mika! Why didn't you tell me that two weeks ago?! LaughingLaughingLaughing
    You didn't ask! Big Smile Remember when building the next pair Wink
    I'd love to hear these. Are you going to add some kind of an internal crossover so the tweeters stay safe from low frequency power?
    -mika
  • 07-26-2011 1:40 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Leslie:
    Evan, you should call them Babyvox 2500, a new b&o baby has born. Positiv critics though, hope you don't mind. The base you're using now makes the cubes smaller. Why not using the sime dims? Where did you buy the tweeter and has it the same size as the originals. Any specs of these on the net? Keep up postingYes -  thumbs up Really enjoy your thread(s) with all the pictures.
    Don't mind at all. I did not fabricate the bases myself, just found a suitable substitute. The dimensions of the stand are not published, so I just went for it. Plus I do not know of any machining businesses, also on a budget.
    The tweeters are not direct replacements. These are Dayton ND20FB-4 tweeters. There are many variants, one that is press fit, then front and rear mount. I chose the rear mount ver so that it would have a flush surface on the exterior. The specs aren't bad either, Freq range 3500-25000Hz, free air resonance ~2100hz, 15w rms power handling, 19mm silk dome. I got my set from Parts Express.
    And to answer Mika's Q - they will be getting a filter. Hopefully I will be able to get away without putting in a notch filter in (seems like a pain). For exactly 3500+ Hz I need a 10-11uF cap. I bought a pair of these at Radioshack yesterday, they are 50v I think. Only for testing. I will probably end up having to make an external filter, I also want to include and L-pad for adjustment.
    Evan
  • 07-26-2011 1:43 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    tournedos:
    Noted!
    Re: the filter - see above. They will be connected directly to an amp so they will need some heavier caps probably. If you want to hear a set, I could always put these into production!
    Evan
  • 07-26-2011 1:49 PM In reply to
    Check out Beovox 5000 service manual on site - it contains the schematics for at least three different old Beovoxes that had the connector for the real cubes. Apparently they all manage with a single cap in series with the cube.
    (I believe the original cubes have a filter cap inside as well?)
    -mika
  • 07-26-2011 1:52 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Here they are sitting on my BeoVox 2600s. A good period setting for my brand new 2011 BeoVox 2500! Cool
    @ Leslie, This is not their final resting place, they will be sitting on my massive JBLs in my monster system. Pictures coming soon.
    Evan
  • 07-26-2011 2:55 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    tournedos:
    Okay, lookng over the MK2 schematic I see one cap in front of the output socket. Its rated at 4.7uF, 12V. Yes from what i have read, I believe there is an internal cap in the 2500 but I do not know its value.
    Being that I have completely different drivers, I haven't really paid much attention to original schematics/values. I've built a very different animal technically, but I'm sure it would make a great addition to someone's BeoLab 5000 system!
    Evan
  • 07-26-2011 3:22 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Evan:
    Leslie:
    The tweeters are not direct replacements. These are Dayton ND20FB-4 tweeters. There are many variants, one that is press fit, then front and rear mount. I chose the rear mount ver so that it wouhave a flush surface on the exterior. The specs aren't bad either, Freq range 3500-25000, free air resonance ~2100hz, 15w rms power handling, 19mm silk dome. I got my set from Parts Express.
    I still have some caps I was trying to give away.  Want all of these to experiment with:
    Update May 9
    Remaining:
    Two ERSE 8.2 uF (+/- 10%)
    Two (no manufacturer on part) 12 uF (no tolerance on part)
    Three One ERSE 15 uF (+/- 5%)
    Two BENNIC 22 uF (+/- 10%)
    One ERSE 33 uF (+/- 5%)
    Two ERSE 47 uF (+/- 5%)
  • 07-26-2011 5:43 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Ah! No foolin Rich?
    Those 8.2s and 12s would be perfect!
    Evan
  • 07-26-2011 5:51 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Evan:
    Ah! No foolin Rich?
    PM me your address and they'll be on their way the next day.
  • 07-26-2011 6:46 PM In reply to
    Evan, check my Picasa webalbum where I disassembled my 2500's.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 07-26-2011 6:57 PM In reply to
    Evan, a new project has startedSmile thanks to you....
    Will start this in a new thread.
  • 07-26-2011 8:22 PM In reply to
    Rich:
    Evan:
    Are they that badly damaged????? LaughingLaughingLaughingLaughingLaughing
    My B&O: 2009 Catalogue and Pricelist
  • 07-26-2011 9:59 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Leslie:
    Way to go Leslie!!
    I will be watching with great interest! Looks like you are going for a replica, doing it the right way!! Yes -  thumbs up
    Evan
  • 07-27-2011 2:13 AM In reply to
    Have the same passion as you I guess (lots of ideas and bringing them alive).
    Can you or others tell me what tweeters I have to look for regarding to ohms and frequence? The originals are 6 ohms. Saw this on a Dutch webshop. Need 12, so have to start with a cheap alternative...
  • 07-27-2011 3:08 AM In reply to
    Why not use cone tweeters? The disadvantage of cones is that they are more directional than domes but as you are mounting 6 in each cube, this is not a problem. A good cone can be very good in the right circumstances!
  • 07-27-2011 10:05 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Leslie:
    This Beoviris is great, isn't it? Wink
    As you know, the originals are cone tweeters. Since you will have top-mounting, your options are pretty much whatever you prefer. The difficult part regarding impedance is that the original was 6 ohms which is going to be hard to find in a modern tweeter.
    I chose silk dme tweeters because I like the way they sound, the Dayton tweeters I have bought are 4 ohms a piece. I have arranged each set of 6 tweeters to have a total impedance of 6 ohms.
    THIS is where I bought my tweeters.
    Evan
  • 07-27-2011 10:23 AM In reply to
    Evan:
    Throw my hat in the ring as well! Laughing
    With time permitting, I hope to have sample "clones" by the end of this year. Not bad considering the project started last year! Embarrassed
    • B&o bottle opener
  • 07-27-2011 12:16 PM In reply to
    Peter :
    So Peter, if I take cones where can you find such small ones that fits in the cube. The impedance does not really matter, I can choose from 4 to 8 ohms and what about the inside cap? Sorry, but no knowledge at all regarding to speakers. Any suggestions where I could by these cones, if possibly cheap (less the 10 euro each)? Hope Frede is reading this thread and my question.
