Latest post 03-08-2011 1:54 AM by Peter. 13 replies.
Page 1 of 1 (14 items)
  • 03-06-2011 4:45 PM
    My first B&O
    So I’m planning to build a stereo purely to play vinyl on, would any one have suggestions for great but affordable speakers from bang and Olufsen that I should get?
    I’ve never really dealt with the company before but my dad loves the stuff so he suggested buy off them.
    Things to note ; I’m not planning to buy any thing brand new it will just be second hand stuff probably quite old that I can find on ebay
    My price range is that of a university student so under £500
    Is it worthwhile buying any second hand B&O products regardless of age? and should I consider purchasing a second hand turntable off them (ive read a few horror stories).
    Thanks for any suggestions or advice
  • 03-06-2011 4:54 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: My first B&O
    Totally worthwhile!!!
    For speakers I would suggest the BeoVox S45-2 or similar.
    If I were looking for another receiver, I would probably get another BeoMaster 3000 or 4000. Both have built in RIAA preamplifiers.
    Evan
  • 03-06-2011 4:57 PM In reply to
    Re: My first B&O
    Thank you Evan i shall have a look into that now
  • 03-06-2011 4:58 PM In reply to
    Re: My first B&O
    I would look for a Beosystem 5500 with possibly some S45.2 speakers - excellent sound, easy to wipe clean (you are a student!) Big Smile but good performance and will work with the modern equipment. If remote is not your thing, then the world is your oyster - a Beomaster 4400 , Beogram 4002 and some S75 speakers will blow away almost anything on the market today, all for less than £500.
  • 03-06-2011 5:09 PM In reply to
    Re: My first B&O
    Thanks for your help Peter thats a really impressive set of equipment i was looking at the turntables from this earlier.
    Any opinions on the B&O Beolab 2500 active speakers , i like the fact i wouldnt need a preamp for them ? and i see them priced at £375
  • 03-06-2011 5:25 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: My first B&O
    aidyanimal:
    They have their place, but will not have the depth and warmth as all of the above equip.
    Back to you're old account Peter?
    Evan
  • 03-06-2011 5:32 PM In reply to
    Re: My first B&O
    Beomaster 4400, Beogram 400x and Beovox S75's are one of the best B&O systems available, Beomaster 6000(80's version), Beogram 800x with the S-75's also works great.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 03-06-2011 5:58 PM In reply to
    Re: My first B&O
    You can get active speakers - the Beolab 2500 are a little specialised as, in my view anyway, they look a bit odd separated from the music system. If you want actives, Beolab 4000s are the best value by far. A Beomaster 4400 and S45s will sound better though! (I have both). The 2500 is probably the weakest of the Beolab speakers - only the Beolab 4 will be less powerful and less capable.
    Changed back to this log in despite having to post a number of times!!
  • 03-07-2011 3:07 AM In reply to
    • Alex
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: My first B&O
    My 2c - don't go for a B&O turntable. With your sort of budget, you can't really afford to buy a lemon. A B&O deck is likely to at least need a service if it hasn't had one recently.
    Having heard one recently, I was extremely impressed with the Rega RP1. They cost around £225, which is a fairly smart amount of your budget to spend on a deck IMO. Cheap turntables are generally awful, verging on unusuable. A low quality, badly set-up turntable will sound terrible, and in many cases, can actually ruin your records. The Rega RP1 comes with a pickup/cartridge, and is already configured and ready to go when you get it out of the box! Don't faff with the playing weight, anti-skate or tracking angle as they're already set correctly...
    The RIAA preamps in the 3000 and 4000 aren't the greatest. They will get you by, but a good future upgrade would involve buying a good quality RIAA/phono preamp.
    My favourite B&O amp is the 4400 (probably because it's one of the ones I own Laughing) - a seriously good amplifier which will run in circles around many modern hi-end amps. I've been meaning to line it up against a Bryston amp we have in the recording studio simply to see just how good it really is! The 4400 also has an RIAA amp, but I haven't actually used it!
    As far as speakers go, you've got a large choice when it comes to B&O. Be wary of rotten foam-surrounds on speaker drivers! Not all the BeoVoxes suffer from it, but if it has degraded, then you'll need to factor in having the drivers re-foamed, or avoid them alltogether!
    For a student (like myself), the S45-2 - rubber driver surrounds, sealed boxes, and three way. A little bass light but in a smaller room that's a good thing!
    Here's a link.
    The B&O active speakers are to be avoided IMO. You really need to look at spending £2.5k plus before you get anything worthwhile (with the exception of the BeoLab 4000). The older BeoVox models will blow a lot of the B&O active models out of the water if you put a decent amp behind them...
     Weekly top artists:
  • 03-07-2011 11:58 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: My first B&O
    Alex is right - go vintage! The systems are simply incredible!
    I will never forget the time when my sister rushed into the house thinking I was playing the piano, when it was really my BeoMaster 3000-2 and BeoVox S45-2s playing a track on my iPod! All original and unserviced, incredible stuff.
    I have never heard a 4400, but by judging what everyone says on here it has to be out of this world if it sounds better than my 3000!
    Evan
  • 03-07-2011 12:31 PM In reply to
    Re: My first B&O
    The 4400 is bacally the same as a Beomaster 6000 (80's model), the Beomaster 8000 is similar in specs too, but with two more darlington configurated output transistors for more power Smile
    Re: My first B&O
    Double post!
  • 03-07-2011 8:02 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Re: My first B&O
    aidyanimal:
    Let's see today's conversion rate.....<Google>....1 pound equals $1.62, so 500 pounds is about $810.
    In the last year on Ebay in the U.S. I've purchased:
    Beovox S40, $50 plus $35 shipping = $85
    Beogram RX 2, $25 plus $30 shipping = $55 (Thread in Vintage)
    MMC4 Cartridge, $100
    Beomaster BM2400, $25 plus $30 shipping = $55 (Thread in Vintage)
    Other investments:
    Parts to refoam S40 woofers, $25 (Thread in Workbench forum)
    Caps and other parts to refurbish S40s, $40
    Antenna, conversion cable, and speaker wire for BM2400, $30
    Total investment:  $390 and maybe 12 hours of my time
    That's my current garage system, and it can freaking rock.  The BM2400 and S40s (which are hanging on a wall for crying out loud) paired up very nicely, thank you very much.
    As to some of the other comments, The RX 2 and MMC4 (had one since 1987, now I have two) get no discussion here, so I'm assuming noses are thumbed at them.  But I adore my first RX 2 (21st birthday present from the future Ex Mrs. Rich) which I'm listening to in my bedroom with a pair of Beovox S45-2s.  Perhaps the RX 2 wasn't sold in Europe, but there's ALWAYS at least one of them for sale on Ebay here in the states.
    If you can get a pair of S45-2s, by all means go for it, as was noted above by more than one person.  No foam rot to worry about, but you may have to recap as I did (failing midrange).  I got my pair (flawless exterior except for grill cloth - frets I believe you say across the pond) on Ebay in 2007 for $95 plus $40 shipping.
    So, in short, vintage B&O, big fan, wish I would win another auction, highly recommended, etc.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 03-08-2011 1:54 AM In reply to
    Re: My first B&O
    Nothing wrong with the RX2 though I would maybe go for a 1700 instead - I just like the 4000 series and they have more of a wow factor in the styling department. My first system was a BM2400, BG1902 and P30s, rapidly changed to S75s. That did me for quite some time till I got a BG4004. My more recent systems are sometimes more convenient but not better looking and any sound improvemnt is marginal.
