1st March February 2012
Latest post 03-08-2011 1:54 AM by Peter. 13 replies.
03-06-2011 4:45 PM
aidyanimal
- Joined on 03-06-2011
- Posts 4
So I’m
planning to build a stereo purely to play vinyl on, would any one have suggestions
for great but affordable speakers from bang and Olufsen that I should get?
I’ve never
really dealt with the company before but my dad loves the stuff so he suggested
buy off them.
Things to
note ; I’m not planning to buy any thing brand new it will just be second hand
stuff probably quite old that I can find on ebay
My price
range is that of a university student so under £500
Is it worthwhile
buying any second hand B&O products regardless of age? and should I consider
purchasing a second hand turntable off them (ive read a few horror stories).
for any suggestions or advice
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Totally worthwhile!!!
For speakers I would suggest the BeoVox S45-2 or similar.
If I were looking for another receiver, I would probably get another BeoMaster 3000 or 4000. Both have built in RIAA preamplifiers.
aidyanimal
- Posts 4
Thanks for your help Peter thats a really impressive set of equipment i was looking at the turntables from this earlier.
Any opinions on the B&O Beolab 2500 active speakers , i like the fact i wouldnt need a preamp for them ? and i see them priced at £375
Evan
- Ohio | USA
- Posts 2,601
aidyanimal:
They have their place, but will not have the depth and warmth as all of the above equip.
Back to you're old account Peter?
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Beomaster 4400, Beogram 400x and Beovox S75's are one of the best B&O systems available, Beomaster 6000(80's version), Beogram 800x with the S-75's also works great.
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Peter
- Joined on 02-12-2007
- Posts 9,572
You can get active speakers - the Beolab 2500 are a little
specialised as, in my view anyway, they look a bit odd separated from
the music system. If you want actives, Beolab 4000s are the best value
by far. A Beomaster 4400 and S45s will sound better though! (I have
both). The 2500 is probably the weakest of the Beolab speakers - only
the Beolab 4 will be less powerful and less capable.
Changed back to this log in despite having to post a number of times!!
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
My 2c - don't go for a B&O turntable. With your sort of budget, you can't really afford to buy a lemon. A B&O deck is likely to at least need a service if it hasn't had one recently.
Having heard one recently, I was extremely impressed with the Rega RP1. They cost around £225, which is a fairly smart amount of your budget to spend on a deck IMO. Cheap turntables are generally awful, verging on unusuable. A low quality, badly set-up turntable will sound terrible, and in many cases, can actually ruin your records. The Rega RP1 comes with a pickup/cartridge, and is already configured and ready to go when you get it out of the box! Don't faff with the playing weight, anti-skate or tracking angle as they're already set correctly...
The RIAA preamps in the 3000 and 4000 aren't the greatest. They will get you by, but a good future upgrade would involve buying a good quality RIAA/phono preamp.
My favourite B&O amp is the 4400 (probably because it's one of the ones I own ) - a seriously good amplifier which will run in circles around many modern hi-end amps. I've been meaning to line it up against a Bryston amp we have in the recording studio simply to see just how good it really is! The 4400 also has an RIAA amp, but I haven't actually used it!
As far as speakers go, you've got a large choice when it comes to B&O. Be wary of rotten foam-surrounds on speaker drivers! Not all the BeoVoxes suffer from it, but if it has degraded, then you'll need to factor in having the drivers re-foamed, or avoid them alltogether!
For a student (like myself), the S45-2 - rubber driver surrounds, sealed boxes, and three way. A little bass light but in a smaller room that's a good thing!
Here's a link.
The B&O active speakers are to be avoided IMO. You really need to look at spending £2.5k plus before you get anything worthwhile (with the exception of the BeoLab 4000). The older BeoVox models will blow a lot of the B&O active models out of the water if you put a decent amp behind them...
Weekly top artists:
Evan
- Ohio | USA
- Posts 2,601
Alex is right - go vintage! The systems are simply incredible!
I will never forget the time when my sister rushed into the house thinking I was playing the piano, when it was really my BeoMaster 3000-2 and BeoVox S45-2s playing a track on my iPod! All original and unserviced, incredible stuff.
I have never heard a 4400, but by judging what everyone says on here it has to be out of this world if it sounds better than my 3000!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
The 4400 is bacally the same as a Beomaster 6000 (80's model), the Beomaster 8000 is similar in specs too, but with two more darlington configurated output transistors for more power
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
aidyanimal:
My price
Let's see today's conversion rate.....<Google>....1 pound equals $1.62, so 500 pounds is about $810.
In the last year on Ebay in the U.S. I've purchased:
Beovox S40, $50 plus $35 shipping = $85
Beogram RX 2, $25 plus $30 shipping = $55 (Thread in Vintage)
MMC4 Cartridge, $100
Beomaster BM2400, $25 plus $30 shipping = $55 (Thread in Vintage)
Other investments:
Parts to refoam S40 woofers, $25 (Thread in Workbench forum)
Caps and other parts to refurbish S40s, $40
Antenna, conversion cable, and speaker wire for BM2400, $30
Total investment: $390 and maybe 12 hours of my time
That's my current garage system, and it can freaking rock. The BM2400 and S40s (which are hanging on a wall for crying out loud) paired up very nicely, thank you very much.
As to some of the other comments, The RX 2 and MMC4 (had one since 1987, now I have two) get no discussion here, so I'm assuming noses are thumbed at them. But I adore my first RX 2 (21st birthday present from the future Ex Mrs. Rich) which I'm listening to in my bedroom with a pair of Beovox S45-2s. Perhaps the RX 2 wasn't sold in Europe, but there's ALWAYS at least one of them for sale on Ebay here in the states.
If you can get a pair of S45-2s, by all means go for it, as was noted above by more than one person. No foam rot to worry about, but you may have to recap as I did (failing midrange). I got my pair (flawless exterior except for grill cloth - frets I believe you say across the pond) on Ebay in 2007 for $95 plus $40 shipping.
So, in short, vintage B&O, big fan, wish I would win another auction, highly recommended, etc.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Page 1 of 1 (14 items)
