1st March February 2012
Latest post 12-21-2011 12:40 AM by Evan. 151 replies.
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Re: BeoSystem 4500 Restoration
Only a few passes in, a bug got caught in the crossfire, halt everything! He must be removed. To the garage for my pinpoint needle nose pliers, steady hands!
Evan
- Ohio | USA
- Posts 2,601
The end of the first coat. Looking great so far!
Okay all, I will have to call it quits for the day, time to get ready for work!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
I have a feeling that the final result might look very good!
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Evan, nice thread and very nice work so far.
And to think you're afraid of a little woofer refoam job!!!!
I might have to do something similar to my scratched up, but fully functional BM 2400.
Good luck on the finish....
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Evan
- Ohio | USA
- Posts 2,601
Thanks guys!
Rich:
And yes, frightened!
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Can't wait for the next episode, great job so far
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
Really looking forward what the end result will be... Keep up the good work, Evan.
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Can't quite imagine what this is going to look like atm. But certainly interesting!
Was the panel really beyond recovering by a pro metal polisher?
Evan
- Ohio | USA
- Posts 2,601
Thanks everyone! I have to work today and tomorrow so it is going to move at a snail's pace until next week.
Step1:
My goal is to match the top to the sides and front of the BeoMaster and BeoGram CD. After all, the only color option available on the BeoSystem 4500 is white.
Yes, unfortunately the panels are long gone.
Eugene
- Joined on 12-17-2008
- Posts 589
Maybe I will do the same to mine. Good job.
beotexas
- Joined on 09-03-2010
- Posts 14
Good work and great pics.
I read elsewhere on here that some mirror panels have the flat grey factory paint finish underneath, some people were just removing the polished layer to reveal the near new factory grey finish underneath. I think this was on the 9500 mirror panels. not sure it applies to the 4500.
Evan
- Ohio | USA
- Posts 2,601
beotexas: Good work and great pics. I read elsewhere on here that some mirror panels have the flat grey factory paint finish underneath, some people were just removing the polished layer to reveal the near new factory grey finish underneath. I think this was on the 9500 mirror panels. not sure it applies to the 4500.
Hello BeoTexas,
Thank you, first off! I'm pretty sure that what you are referring to is the BeoSystem 3500 that has a grey top coat.
Evan
- Ohio | USA
- Posts 2,601
Eugene:
I encourage you do the same Richard, if your panels are showing their age, this is a great alternative to freshen up the look.
Evan
- Ohio | USA
- Posts 2,601
Hello and welcome back!
By now the lid's first coat of paint is well dried and is ready for more.
Before it left my "library" for more paint, I used some more 400 grit sandpaper to knock down some of the imperfections and paint build up from the first session.
Here, I have elevated the lid onto a pair of found baskets from the garage. I can now spray the ultra-thin front and side edges of the metal component. Be prepared for some precision tape work!
Evan
- Ohio | USA
- Posts 2,601
It is hard to tell the difference, but another spraying is complete.
Here in the early evening, I am annoyed with curious insects. I must protect the finish! The lid has been moved inside the screened in porch to dry.
Keeping a flawless finish is getting increasingly more difficult. Little fibers seem to be attracted to the wet surface, as well as other particles. Very trying!
Evan
- Ohio | USA
- Posts 2,601
On the operating table: The BeoMaster 4500
Time to prepare the BeoMaster for its respray. It will be resprayed with the same paint as the lid so it will match afterwards.
Evan
- Ohio | USA
- Posts 2,601
Before the master is fully masked off for paint, the front and sides need to be roughed up to ensure good adhesion.
Evan
- Ohio | USA
- Posts 2,601
Another good reason to sand these surfaces is to remove the 20+ years of blemishes that this unit has acquired.
Evan
- Ohio | USA
- Posts 2,601
Once all sanding is complete, the unit needs to be wiped down with a damp wrag to remove the superfine dust before paint.
Evan
- Ohio | USA
- Posts 2,601
To be absolutely certain the bottom edges of the sides are well taped off, I propped up each side of the BeoMaster on an assembly manual.
Steffen
- Joined on 06-24-2008
- Denmark
- Posts 281
evman140:
Hello BeoTexas,
Yes -it's a grey topcoat. Painted on the polished aluminum. Not the other way around. People were removing the grey paint to get to the polished surface. It's an aluminum plate, beotexas -there's no paint underneath.
Evan
- Ohio | USA
- Posts 2,601
Where to put the power cord?
At first I wasn't sure about what to do with the power cord for when this unit gets painted. I had a stroke of genius and tied the cable in the socket cavity so that it could be covered when I wrap the Master.
Evan
- Ohio | USA
- Posts 2,601
All it took was a half mile of tape, one sheet of the sports section and a glass of iced tea.
Tomorrow morning should be the end of painting the BeoMaster and its lid. Very exciting!
I shall call it a night.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
PM me your address & I'll send you some same spec'ed foam tape.
Chris.
