Latest post 12-21-2011 12:40 AM by Evan. 151 replies.
Page 2 of 7 (152 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 09-17-2010 11:48 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: BeoSystem 4500 Restoration
    DSCN1178.jpg picture by evman140
    Only a few passes in, a bug got caught in the crossfire, halt everything! He must be removed. To the garage for my pinpoint needle nose pliers, steady hands!
    Evan
  • 09-17-2010 11:50 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1179.jpg picture by evman140
    The end of the first coat. Looking great so far!
    Okay all, I will have to call it quits for the day, time to get ready for work!
    Evan
  • 09-17-2010 12:33 PM In reply to
    I have a feeling that the final result might look very good!
    -mika
  • 09-17-2010 2:59 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Evan, nice thread and very nice work so far.
    And to think you're afraid of a little woofer refoam job!!!!
    I might have to do something similar to my scratched up, but fully functional BM 2400.
    Good luck on the finish....Yes -  thumbs up
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-17-2010 3:10 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thanks guys!
    Rich:
    And yes, frightened! Laughing
    Evan
  • 09-17-2010 3:38 PM In reply to
    Can't wait for the next episode, great job so farYes -  thumbs up
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-18-2010 3:09 AM In reply to
    Really looking forward what the end result will be... Keep up the good work, Evan. Yes -  thumbs up
  • 09-18-2010 6:39 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Can't quite imagine what this is going to look like atm. But certainly interesting!
    Was the panel really beyond recovering by a pro metal polisher?
    Olly.
  • 09-18-2010 8:43 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thanks everyone! I have to work today and tomorrow so it is going to move at a snail's pace until next week.
    Step1:
    My goal is to match the top to the sides and front of the BeoMaster and BeoGram CD. After all, the only color option available on the BeoSystem 4500 is white.
    Yes, unfortunately the panels are long gone.
    Evan
  • 09-18-2010 1:41 PM In reply to
    Maybe I will do the same to mine. Good job.
  • 09-18-2010 4:25 PM In reply to
    Good work and great pics. I read elsewhere on here that some mirror panels have the flat grey factory paint finish underneath, some people were just removing the polished layer to reveal the near new factory grey finish underneath. I think this was on the 9500 mirror panels. not sure it applies to the 4500.
  • 09-18-2010 6:51 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    beotexas:
    Hello BeoTexas,
    Thank you, first off! I'm pretty sure that what you are referring to is the BeoSystem 3500 that has a grey top coat.
    Evan
  • 09-18-2010 7:10 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Eugene:
    I encourage you do the same Richard, if your panels are showing their age, this is a great alternative to freshen up the look.
    Evan
  • 09-18-2010 7:20 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Hello and welcome back!
    DSCN1182.jpg picture by evman140
    By now the lid's first coat of paint is well dried and is ready for more.
    Before it left my "library" for more paint, I used some more 400 grit sandpaper to knock down some of the imperfections and paint build up from the first session.
    Here, I have elevated the lid onto a pair of found baskets from the garage. I can now spray the ultra-thin front and side edges of the metal component. Be prepared for some precision tape work!
    Evan
  • 09-18-2010 7:30 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1181.jpg picture by evman140
    It is hard to tell the difference, but another spraying is complete.
    Here in the early evening, I am annoyed with curious insects. I must protect the finish! The lid has been moved inside the screened in porch to dry.
    Keeping a flawless finish is getting increasingly more difficult. Little fibers seem to be attracted to the wet surface, as well as other particles. Very trying!
    Evan
  • 09-18-2010 9:18 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1185.jpg picture by evman140
    On the operating table: The BeoMaster 4500 Stick out tongue
    Time to prepare the BeoMaster for its respray. It will be resprayed with the same paint as the lid so it will match afterwards.
    Evan
  • 09-18-2010 9:20 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1186.jpg picture by evman140
    Before the master is fully masked off for paint, the front and sides need to be roughed up to ensure good adhesion.
    Evan
  • 09-18-2010 9:22 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1189.jpg picture by evman140
    Another good reason to sand these surfaces is to remove the 20+ years of blemishes that this unit has acquired.
    Evan
  • 09-18-2010 9:26 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1188.jpg picture by evman140
    Once all sanding is complete, the unit needs to be wiped down with a damp wrag to remove the superfine dust before paint.
    Evan
  • 09-18-2010 9:30 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1191.jpg picture by evman140
    To be absolutely certain the bottom edges of the sides are well taped off, I propped up each side of the BeoMaster on an assembly manual.
    Evan
  • 09-18-2010 10:13 PM In reply to
    evman140:
    beotexas:
    Hello BeoTexas,
    Yes -it's a grey topcoat. Painted on the polished aluminum. Not the other way around. People were removing the grey paint to get to the polished surface. It's an aluminum plate, beotexas -there's no paint underneath.
  • 09-18-2010 10:52 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Where to put the power cord?
    DSCN1192.jpg picture by evman140
    At first I wasn't sure about what to do with the power cord for when this unit gets painted. I had a stroke of genius and tied the cable in the socket cavity so that it could be covered when I wrap the Master.
    Evan
  • 09-18-2010 10:57 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1193.jpg picture by evman140
    All it took was a half mile of tape, one sheet of the sports section and a glass of iced tea.
    Tomorrow morning should be the end of painting the BeoMaster and its lid. Very exciting!
    I shall call it a night.
    Evan
  • 09-19-2010 9:56 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    As I near assembly of the BeoMaster, I will need to select an adhesive for the operation panel bezel pieces. Any suggestions?
    Evan
  • 09-19-2010 10:13 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    PM me your address & I'll send you some same spec'ed foam tape.
    Chris.
