Hello,
I've been searching the internet for quite some while now for my issues. I have found my issue twice, both times unanswered. So perhaps its an easy solution, or an impossible one.
I recently purchased a beogram 1700 in not too great condition, I more or less rescued it from the bin. But all the mechanisms seem too work.
However,
When the tonearm is in its resting position it almost hits the aluminium. When I purchased it the problem was it had hit the deck. I have adapted this by raising the tiny support screw at the base of the tonearm. (this littlescrew rests on the 'thing' that is being raised or lowered). My tonearm now sits horizontally at the base, but when I press play the tonearm turns to the record, while being raised and now is about 1 cm above the record. This seems to high for me, especially compared to the beogram 1600 i have.
Comparted to my beogram 1600 the arm is raised when approaching the platter (and the more you move the arm manually to the center the more it is raised). I found somewhere on the net that it is normal for a 1700 tonearm to do this. But how high should the arm be in rest position, and how high before beeing slightly dropped on the record?
The second issue is that the after playing the arm swings back but does not stop at a 90 degree angle with the deck. It moves too far. In some other manuals i found that the stop position could be adusted, however i dont know where to adjust such a thing on my deck. (i have located the two asymetric screws for adjusting the drop position for 45's and 33's, and the landing is not an issue, so this is not an option?: http://forum.beoworld.org/forums/t/39785.aspx). I have a manual which does not mention such a thing.
What i have done is lubricating the pot which lowers and raises the arm. I think thats not the problem as the arm does not skate across the record or anything. What seems to be the problem is that the arm is dropped to much when moving away from the record. I have search the www and so far did not find anything that could help.
Any tips, or expereriences with the height of the tonearm are really appreciated.
I want to get this thing perfectly running, cause my beogram 1600 does not play my 33rpm singles, or 45 rpm 17inch (hardcorepunk and dance). It does play my stones records fine though.
Thanks in advance!
