Latest post 09-28-2011 8:13 AM by deaddruid. 2 replies.
Page 1 of 1 (3 items)
  • 09-28-2011 4:50 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Using V.AUX for an audio input
    On an Avant RF VCR, I now have inputs on both SAT and V.AUX which are each capable of supplying video+audio or audio alone. I can select audio mode on the SAT input via a Beo4 by selecting AV (by pressing LIST several times), GO, SAT. This then enables the speakers but leaves the screen switched off. I cannot seem to do the same with V.AUX, since AV (via LIST), GO, V.AUX (via LIST), GO switches into the full (video+audio) V.AUX mode. I want to avoid screen-burn when listening to radio stations via V.AUX.
    How can I select an audio-only mode on V.AUX?
    Mark
  • 09-28-2011 6:53 AM In reply to
    Re: Using V.AUX for an audio input
    Hi Mark,
    the command A-V.AUX (via LIST) will do the job. Probably your Beo4 has this command and you can ADD it to your Beo4.
    Regards
    Räuber
  • 09-28-2011 8:13 AM In reply to
    • deaddruid
    • Posts 247
    Excellent! I hadn't noticed that option. Thank you.
    Mark
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
