Hi all!!
Where can I find the Beo5 configuration software?
I have bought my self a used Beo5 and need the software to configure it as I want.
Thanks!
regards
Niklas
To my knowledge, you are not allowed to get the software, it is only for dealers. Maybe you can find a corrupt dealer, that will help you with it, but I'm not sure, especially since you have not bought the Beo5 as new from them. But good luck.
Remember it is your own risk.
BEO5 Configuration Tool 3.87. 2010 kan hentes her.
http://www.megaupload.com/?d=0IQNQ8S5
/ Peter Pan.
