Latest post 10-12-2010 4:29 AM by Peter Pan. 2 replies.
Page 1 of 1 (3 items)
  • 10-11-2010 2:49 PM
    • ngolve
    • Not Ranked
    • Joined on 09-25-2010
    • Posts 4
    Beo5 configuration software
    Hi all!!
    Where can I find the Beo5 configuration software?
    I have bought my self a used Beo5 and need the software to configure it as I want.
    Thanks!
    regards
    Niklas
    Filed under:
  • 10-12-2010 3:07 AM In reply to
    • Molotow
    • Not Ranked
    • Joined on 06-09-2007
    • Herning
    • Posts 50
    Re: Beo5 configuration software
    To my knowledge, you are not allowed to get the software, it is only for dealers. Maybe you can find a corrupt dealer, that will help you with it, but I'm not sure, especially since you have not bought the Beo5 as new from them. But good luck.
  • 10-12-2010 4:29 AM In reply to
    Remember it is your own risk.
    BEO5 Configuration Tool 3.87. 2010 kan hentes her.
    http://www.megaupload.com/?d=0IQNQ8S5
    / Peter Pan.
