Latest post 01-30-2012 2:33 PM by mbee. 249 replies.
Page 7 of 10 (250 items) « First ... < Previous 5 6 7 8 9 Next > ... Last »
  • 07-30-2010 6:12 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: The unique, one and only SOFTWARE UPDATE THREAD!
    ML Delay is Grayed out on MK4 with software 9.01.
    edit: If the ML is grayed out and you have DSM module 2.0 or higher AST needs to be in the menu but does not have to be switched on just present.
    If AST does not appear then the DSM FEP and DSM DSP software are to old
    This is seperate from the H8 Software we normally talk about.
    My TV has 9.01 but the DSM module sw is 4.23a and 4.19 which is to old for AST to be shown.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 07-30-2010 8:45 AM In reply to
    Some posts here have discussed the update that replaces the clock with the words Bang and Olufsen at start up. Is that a feature absent from US TVs? We had a 7-40 mkIII and now have a 7-55 and have never had a clock at startup? If we updated the software on the 7-55 would we have the B and O logo? Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 07-30-2010 10:41 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Hi Razlaw,
    The clock issue is only linked to the DVB-HD module... And the diffusion format in US is not DVB, I think... So the module is not the same, so your updates (and issues) must be different!
  • 07-30-2010 5:27 PM In reply to
    Thanks. Was Hoping it would be possible to have the screen show Bang and Olufsen.
  • 08-01-2010 6:53 AM In reply to
    • fl4f
    • Not Ranked
    • Joined on 01-21-2010
    • Posts 15
    I had my BV8-40 updated from something less than build 68 to build 127 for 3 week ago. And OMG its almost like a complety new tv :-)
    The picture is more clear and the colors is more crisp, even in the std. settings.
    I had no issus with the tv before the update. But actually I have two things now, which I would categorize as minor issues/bugs.
    Some times the internal fans is humming with sound high enough to be annoying.
    I have CD player connected to the tv through SPDIF, when using the cdplayer. The tv now turns it self off every half hour or so. I have been fiddling around in the menus to se if this somehow is a standby setting or something. But no luck. Also a bit annoying :-)
    This build 127 is pretty much what, the BV8 should have been released with in the first place. Im very pleased with it.
    Filed under:
  • 08-01-2010 8:59 PM In reply to
    • splud
    • Not Ranked
    • Joined on 02-11-2008
    • Western Australia
    • Posts 42
    Hi Guys, I got the BV7 MkIV without Bluray player and have performed the usb software upgrade, quick question...Does the 1.4.7 software only upgrades the DTV or does the BV7 get a software upgrade too as mine is showing build 8 I think?
    Cheers TC
  • 08-02-2010 2:04 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    fl4f:
    I had no issus with the tv before the update...
    Then how did you get your dealer to organise the update? Here in the UK B&O will only software upgrade your TV if you experience a known issue. They won't just come around and install for free. It's possible to pay for a couple of hours of engineering time, but this isn't cheap.
    I could do with a few products being updated. My old BC2, BV8 and BV7 (sw 7.05).
  • 08-02-2010 2:34 AM In reply to
    fl4f:
    So I'm not the only one!? The fans in my BV8-40 starts humming after 20-30 minutes of use. Extremely irritating. This started when I updated the DVB-HD module back in May. My dealer has tried changing a couple of things in the television, but nothing has helped yet. The humming is really irritating, especially at night, when watching television at low volume.
    fl4f:
    Couldn't agree more!!! Stick out tongue
    I was the second place winner on the BeoWorld May 2009 Prize Draw!
    Thanks to BeoWorld for a great site!
    Filed under: ,
  • 08-02-2010 4:27 AM In reply to
    Hi Guys,
    I have had a look through and cannot find any reference to the updates for a BV7-40 MK2, do anybody have a list of the fixes/additional options etc for this model.
    A good idea would be to create a sticky thread for each model to show the latest software & fixes etc with another sticky for feedback for each model as one thread for all the models is not very clear with everybody replying to parts of their model/update.
    What do you think?
    Simon
    Filed under:
  • 08-02-2010 5:03 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    or maybe a new area seperate from General with the top level being called Software and each product within that one.
    I think this woudl be a good idea
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 08-02-2010 7:44 AM In reply to
    I would second that suggestion. Excellent idea.
  • 08-04-2010 4:04 AM In reply to
    • flx
    • Not Ranked
    • Joined on 12-08-2009
    • Belgium (Tienen area)
    • Posts 25
    • Gold Member
    Does build v127 for BV8 includes both the BV8-40 and BV8-32 ?
    Thx
  • 08-06-2010 8:34 AM In reply to
    • Odd88
    • Top 500 Contributor
    • Joined on 07-25-2010
    • Norway
    • Posts 86
    • Gold Member
    how can I tell what software version I have in my bv8-40?
    Blame google translate for my bad EnglishStick out tongue
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
    • Beolab: 5/3/2/8000
    • Beo 5 / Beo 4 / Beotime
    • Form 2 / A8 Earphones
  • 08-08-2010 5:39 AM In reply to
    • KMH789
    • Not Ranked
    • Joined on 12-28-2009
    • Posts 4
    Hej
    Som jeg læser det (se nedenstående), er det så korrekt, at der er kommet en ny opdatering til BV10-40 dvs. version 0.1.4.7 (jeg har lige tjekket og har nemlig version 0.1.4.5 og vil derfor gerne lave en opdatering til den nye version) , og er der nogle der kender changelog?
    Mvh. Knud
    DVB HD (MKI/MKII) module (found on BV7, BV8 and BV10) : latest version :0.1.4.7 - 11/06/2010
    This software update can be done by the user : download it here : http://www.bang-olufsen.com/dvb-hd/software-downloads
    0.1.4.5 - 12/05/2010
  • 08-12-2010 2:37 PM In reply to
    I have update mu BV9 to 9.01 now...BUT why is there not any option to use Beo4 MKII???? BV7 and BV4 have this!!! MY BV9 for 22 000€ does not work with my new Beo4!!!!!! Whats the problem Struer??
  • 08-13-2010 4:45 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    mr_anders_son:
    My BV4 doesn't have that option either. Even with 9.01.
    My BS3 is MKI i don't know if that is why.
    /Weebyx
  • 08-13-2010 12:31 PM In reply to
    • tompa
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    I think you need hardware uppgrade, check in customer menu if IOP SW is below 23.00 (early BS3MK1 and BV9) if so, that is the problem
    and you have to change AVS/H8 module
    /Tompa
  • 08-13-2010 1:10 PM In reply to
  • 08-15-2010 9:50 AM In reply to
    • tompa
    • Sweden
    • Posts 94
    I don't now price for it, but call your local B&O service for price
    /Tompa
  • 10-11-2010 6:27 PM In reply to
    This thread really should be pinned. It's more useful than many of the pinned threads.
  • 10-20-2010 11:20 AM In reply to
    Hi, I have a Beovision 7-55 and have upgraded my software to 9.01. I experience a problem whith the contrast. When I start up the TV the contrast will go upp at maximum and after 1 minute it will slowly go back to normal. I didn´t have this problem with software 8.12. Does anybody else experience the same problem?
    My second question is if SW 9.01 is the latest software?
    Regards
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 10-20-2010 1:14 PM In reply to
    Latest available soft ware 2010.10.12:
    BEOSYSTEM 3MK 1, 960X-961X & BEOSYSTEM 3, MK 2, 9615-9628 :
    Version 9.01/build 714
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 10-28-2010 10:08 AM In reply to
    • BeoGreg
    • Joined on 07-24-2008
    • South of France
    • Posts 139
    • Gold Member
    Hello Peter and Svend fans,
    I got build 153 today for my BV10-40 after an intervention of my technician.
    First noticable change : the beo4 "with navigation wheel" works like a charm with my french cable tv set top box (Numéricable).
    No more go + up or down, only up or down to change channel.
    Didn't have the time for more investigation !
    Cheers,
    Gregory
    Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...
  • 11-08-2010 11:42 AM In reply to
    SW 10.02, build 8.14 for BS3 televisions is now available.
    Fix a lot of issues on BV 7 including MY problem with 24p material :-)
    Furthermore fixes an issue with the tv dimming after a while.
    Introduces the possibility to deactivate centerspeaker.
    Delays the fans for 20 sec. to let the tv start up and cover the fannoise. before they start.
    Other issues has been fixed aswell
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 11-08-2010 2:02 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    ohhhh anything else important to note.
    My build seems to be fine for me but its always interesting to note what changes have / can be made.
    Seanie
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
