        1st March February 2012
	    Latest post 01-30-2012 2:33 PM by mbee . 249 replies.
									                 Seanie_230
 Joined on 04-20-2007Milton Keynes, EnglandPosts 962 |
										    Re: The unique, one and only SOFTWARE UPDATE THREAD!
										    ML Delay is Grayed out on MK4 with software 9.01. edit: If the ML is grayed out and you have DSM module 2.0 or higher AST needs to be in the menu but does not have to be switched on just present. If AST does not appear then the DSM FEP and DSM DSP software are to old This is seperate from the H8 Software we normally talk about. My TV has 9.01 but the DSM module sw is 4.23a and 4.19 which is to old for AST to be shown.   Beovision 7 MKIV (Blu Ray)Beolab 9
 Beolab 6000
 Beo 4
 Beocenter 9300
 Apple TV
 SKY HD
 Optoma HD65 Projector
 Lintronic TT455-RT-238
 Beovision 3 MKII
									                 RazlawJoined on 04-24-2007IllinoisPosts 1,770 |
										    Some posts here have discussed the update that replaces the clock with the words Bang and Olufsen at start up. Is that a feature absent from US TVs? We had a 7-40 mkIII and now have a 7-55 and have never had a clock at startup? If we updated the software on the 7-55 would we have the B and O logo?
Thanks! Beovision 7-55 with Beolab 7-4, 9s and 4000s Beovision 10-40 with Beolab 1s and 6000s Beosound 1, 5, 2000, and 3000 Beotime, Beotalk, Beocoms |  |
									                 mbeeJoined on 04-18-2007Paris, FrancePosts 1,133 |
										    Hi Razlaw, The clock issue is only linked to the DVB-HD module... And the diffusion format in US is not DVB, I think... So the module is not the same, so your updates (and issues) must be different! |  |
										    Thanks. Was Hoping it would be possible to have the screen show Bang and Olufsen. Beovision 7-55 with Beolab 7-4, 9s and 4000s Beovision 10-40 with Beolab 1s and 6000s Beosound 1, 5, 2000, and 3000 Beotime, Beotalk, Beocoms |  |
									                 fl4fJoined on 01-21-2010Posts 15 |
										    I had my BV8-40 updated from something less than build 68 to build 127 for 3 week ago. And OMG its almost like a complety new tv :-) The picture is more clear and the colors is more crisp, even in the std. settings.    I had no issus with the tv before the update. But actually I have two things now, which I would categorize as minor issues/bugs.  Some times the internal fans is humming with sound high enough to be annoying. I have CD player connected to the tv through SPDIF, when using the cdplayer. The tv now turns it self off every half hour or so. I have been fiddling around in the menus to se if this somehow is a standby setting or something. But no luck. Also a bit annoying :-)   This build 127 is pretty much what, the BV8 should have been released with in the first place. Im very pleased with it. |  |
									                 spludJoined on 02-11-2008Western AustraliaPosts 42 |
										    Hi Guys, I got the BV7 MkIV without Bluray player and have performed the usb software upgrade, quick question...Does the 1.4.7 software only upgrades the DTV or does the BV7 get a software upgrade too as mine is showing build 8 I think? Cheers TC |  |
									                 moxxeyJoined on 04-14-2007South West, UKPosts 2,360 |
										     fl4f:
I had no issus with the tv before the update...
 Then how did you get your dealer to organise the update? Here in the UK B&O will only software upgrade your TV if you experience a known issue. They won't just come around and install for free. It's possible to pay for a couple of hours of engineering time, but this isn't cheap. I could do with a few products being updated. My old BC2, BV8 and BV7 (sw 7.05).   |  |
									                 ClausMikkelsenJoined on 03-13-2009Posts 82 |
										     fl4f:Some times the internal fans is humming with sound high enough to be annoying.
 So I'm not the only one!? The fans in my BV8-40 starts humming after 20-30 minutes of use. Extremely irritating. This started when I updated the DVB-HD module back in May. My dealer has tried changing a couple of things in the television, but nothing has helped yet. The humming is really irritating, especially at night, when watching television at low volume.    fl4f:This build 127 is pretty much what, the BV8 should have been released with in the first place. Im very pleased with it.
 Couldn't agree more!!!    I was the second place winner on the BeoWorld May 2009 Prize Draw! Thanks to BeoWorld for a great site! |  |
									                 beolife
 Joined on 04-19-2007Posts 163 |
										    Hi Guys, I have had a look through and cannot find any reference to the updates for a BV7-40 MK2, do anybody have a list of the fixes/additional options etc for this model. A good idea would be to create a sticky thread for each model to show the latest software & fixes etc with another sticky for feedback for each model as one thread for all the models is not very clear with everybody replying to parts of their model/update. What do you think?   Simon |  |
									                 Seanie_230
										    or maybe a new area seperate from General with the top level being called Software and each product within that one. I think this woudl be a good idea Beovision 7 MKIV (Blu Ray)Beolab 9
 Beolab 6000
 Beo 4
 Beocenter 9300
 Apple TV
 SKY HD
 Beovision 3 MKII
										    I would second that suggestion. Excellent idea. Beovision 7-55 with Beolab 7-4, 9s and 4000s Beovision 10-40 with Beolab 1s and 6000s Beosound 1, 5, 2000, and 3000 Beotime, Beotalk, Beocoms |  |
									                 flx
 Joined on 12-08-2009Belgium (Tienen area)Posts 25 |
										    Hi, Does build v127 for BV8 includes both the BV8-40 and BV8-32 ? Thx   |  |
									                 Odd88
 Joined on 07-25-2010NorwayPosts 86 |
										    how can I tell what software version I have in my bv8-40? Blame google translate for my bad English My Bang & Olufsen.
Beovision 8-40Beosound 9000Beolab: 5/3/2/8000Beo 5 / Beo 4 / BeotimeForm 2 / A8 Earphones  |  |
									                 KMH789Joined on 12-28-2009Posts 4 |
										    Hej Som jeg læser det (se nedenstående), er det så korrekt, at der er kommet en ny opdatering til BV10-40 dvs. version 0.1.4.7 (jeg har lige tjekket og har nemlig version 0.1.4.5 og vil derfor gerne lave en opdatering til den nye version) , og er der nogle der kender changelog?  Mvh. Knud DVB HD (MKI/MKII) module (found on BV7, BV8 and BV10) : latest version :0.1.4.7 - 11/06/2010 This software update can be done by the user : download it here : http://www.bang-olufsen.com/dvb-hd/software-downloads 0.1.4.5 - 12/05/2010   |  |
									                 mr_anders_sonJoined on 03-27-2007swedenPosts 1,032 |
										    I have update mu BV9 to 9.01 now...BUT why is there not any option to use Beo4 MKII????
BV7 and BV4 have this!!!
MY BV9 for 22 000€ does not work with my new Beo4!!!!!!
Whats the problem Struer?? |  |
									                 Weebyx
 Joined on 06-30-2008DenmarkPosts 321 |
										       mr_anders_son:I have update mu BV9 to 9.01 now...BUT why is there not any option to use Beo4 MKII???? BV7 and BV4 have this!!! MY BV9 for 22 000€ does not work with my new Beo4!!!!!! Whats the problem Struer??
 My BV4 doesn't have that option either. Even with 9.01. My BS3 is MKI i don't know if that is why.   /Weebyx |  |
									                 tompaJoined on 06-30-2007SwedenPosts 94 |
										    I think you need hardware uppgrade, check in customer menu if IOP SW is below 23.00 (early BS3MK1 and BV9) if so, that is the problem and you have to change AVS/H8 module    /Tompa |  |
										    mine is 22.00
how much for that module?? |  |
										    I don't now price for it, but call your local B&O service for price      /Tompa |  |
									                 beojeffJoined on 11-29-2007Posts 543 |
										    This thread really should be pinned. It's more useful than many of the pinned threads. |  |
									                 martin01
 Joined on 04-17-2007SwedenPosts 207 |
										    Hi, I have a Beovision 7-55 and have upgraded my software to 9.01. I experience a problem whith the contrast. When I start up the TV the contrast will go upp at maximum and after 1 minute it will slowly go back to normal. I didn´t have this problem with software 8.12. Does anybody else experience the same problem? My second question is if SW 9.01 is the latest software?  RegardsMartin
 Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version) |  |
									                 talismanJoined on 05-06-2007Posts 52 |
										    Latest available soft ware 2010.10.12:
 BEOSYSTEM 3MK 1, 960X-961X & BEOSYSTEM 3, MK 2, 9615-9628 :
 Version 9.01/build 714
 BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .  |  |
									                 BeoGregJoined on 07-24-2008South of FrancePosts 139 |
										    Hello Peter and Svend fans, I got build 153 today for my BV10-40 after an intervention of my technician. First noticable change : the beo4 "with navigation wheel" works like a charm with my french cable tv set top box (Numéricable). No more go + up or down, only up or down to change channel. Didn't have the time for more investigation ! Cheers, Gregory   Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...    |  |
									                 Ehlerz
 Joined on 04-17-2007DKPosts 510 |
										    SW 10.02, build 8.14 for BS3 televisions is now available. Fix a lot of issues on BV 7 including MY problem with 24p material :-) Furthermore fixes an issue with the tv dimming after a while.  Introduces the possibility to deactivate centerspeaker. Delays the fans for 20 sec. to let the tv start up and cover the fannoise. before they start. Other issues has been fixed aswell   /Ehlerz BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3. |  |
									                 Seanie_230
										    ohhhh anything else important to note. My build seems to be fine for me but its always interesting to note what changes have / can be made.   Seanie Beovision 7 MKIV (Blu Ray)Beolab 9
 Beolab 6000
 Beo 4
 Beocenter 9300
 Apple TV
 SKY HD
 Beovision 3 MKII
