Hi
I just bought a pair of Model 6602 Penta 1 speakers with built in amps. They have been mistreated and will possibly require grilles, some copper coloured trim and 3 inch foam surrounds. Where is best to try for these? I could re-cover my grilles but the one has a piece missing from the frame.
Before deciding whether a restoration is worthwhile I tried to get them running from a CD player/preamp via the phono input. At first both were dead - but mains lights came on when the 3 amp plug fuses were replaced! (why would they have both gone?)
I managed to get the one working and and it sounded remarkable - even with damaged drive units.
The other one showed a red mains light which turned green - when the cd was played - but no sound apart from a feint hum/hss as though the signal was not getting through
I re-connected the first one up - and now that did the same - so I am a little bewildered! Just have a strange feeling it may have something to do with the selection switches .
I would appreciate any help - particularly a copy of an instruction /service manual
I would think they sound quite remarkable when operating correctly!
Please email me direct on djones53@googlemail.com if you can help point me in the right dierction!
Dave
