I bought a nicly looking Beocord 4500 just for £10 yesterday. It has on problem, the cable is cut off at a lenght about 15 cm. How shall I begin with this. Is there anything I can use in splicing the cable, what type of cable etc??
Which cable has been cut - the power cord or the connector?
Chris.
It is the connector cable.
The power cord would not have been a problem.
I was just going through the MCL manuals here the other day.
One of them says the Audio AUX link cable is the same as it has 2 ways of transporting data.
A good dealer should be able to get it.
sveifors: It is the connector cable. The power cord would not have been a problem.
In that case I may be able to help. I have a non-working BC3300 which I can de-solder the cable from & send if it is any use. I'm fairly sure it will do the job although I've never opened a 4500.
Yes thanks Chris that would be nice if you could do that.
Will do mate - PM me with your postal address & your email address so I can send you a couple of photos of the wire positions before I desolder them - they may be useful
I recieved the cable in the post yesterday, Thank you Chris for help. Beoworld is truly a big family.
