Latest post 03-31-2009 3:07 AM by sveifors. 7 replies.
Page 1 of 1 (8 items)
  • 03-04-2009 12:04 PM
    • sveifors
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North of Norway
    • Posts 145
    Beocord 4500 cable
    I bought a nicly looking Beocord 4500 just for £10 yesterday. It has on problem, the cable is cut off at a lenght about 15 cm. How shall I begin with this. Is there anything I can use in splicing the cable, what type of cable etc??
    Sveifors Always look on the B & O side of life
  • 03-04-2009 7:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocord 4500 cable
    Which cable has been cut - the power cord or the connector?
    Chris.
  • 03-05-2009 11:44 AM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    It is the connector  cable.
    The power cord would not have been a problem.
  • 03-05-2009 12:17 PM In reply to
    I was just going through the MCL manuals here the other day.
    One of them says the Audio AUX link cable is the same as it has 2 ways of transporting data.
    A good dealer should be able to get it.
  • 03-05-2009 2:10 PM In reply to
    • Medogsfat
    • Posts 4,045
    sveifors:
    In that case I may be able to help. I have a non-working BC3300 which I can de-solder the cable from & send if it is any use. I'm fairly sure it will do the job although I've never opened a 4500.
    Chris.
  • 03-09-2009 4:26 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Yes thanks Chris that would be nice if you could do that.
  • 03-10-2009 6:30 PM In reply to
    • Medogsfat
    • Posts 4,045
    Will do mate - PM me with your postal address & your email address so I can send you a couple of photos of the wire positions before I desolder them - they may be usefulSmile
    Chris.
  • 03-31-2009 3:07 AM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    I recieved the cable in the post yesterday, Thank you Chris for help. Beoworld is truly a big family.
