I have a Panasonic Plasma in my bedroom that gets the picture signal straight from a hardwired cable from my sky box downstairs whichis all working fine.
My problem is my Panasonic does not have the speakers attached. I am wondering is it possible to use a my spare set of Beolab 4000s (which are sadly sat doing nothing at the mo which is a complete waste) to connect straight to the TV audio speaker outputs (2 connections) ??? Is there some kind of convertor I can use on a powerlink cable.
If not does anyone else have a quick fix way i can get sound to my second TV using my 4000s. i also have a beolink Active box I could use somehow.
cheers
Scott
