        1st March February 2012
	    Latest post 11-02-2008 2:59 PM by  Puncher. 10 replies.
								        10-26-2008 3:29 AM
									        Thomas
								                - Joined on 04-16-2007
								                - Norway
								                - Posts 85
										    Hi People, I have just gotten a beoport and I was wondering if there is a easy way to convert my Apple lossless files to something beoport understands (Without sacrify quality). Thomas
									    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
									        Spiros
								                - Joined on 09-03-2007
								                - Thessaloniki GREECE
								                - Posts 1,088
										    Re: Convert Apple lossless
										    Hi there. I guess this should be posted on the Mac/Apple section!!! Here it's good old PC forum!!!!!!!!!!!
									        PhilLondon
								                - London
								                - Posts 2,545
										      spirost:I guess this should be posted on the Mac/Apple section!!!
 Apple lossless is a codec in iTunes, the most commonly used media player on... PCs!  Thomas seems to have a PC, as on a Mac, iTunes is used instead of Beoport, therefore he would not have to convert.  Thomas,   In iTunes, go to the preferences and in the Import section, chose the codec you want to convert the songs to. AIFF would convert it back to the original CD format, without losing any quality.  Close the preferences, then select all the songs you want to convert and right click and select "Convert to AIFF". All the converted songs will be added to the library itself. Sort your library by "Date added" to separate the old versions from the newer versions. p.
									        Thomas
								                - Norway
								                - Posts 85
										    p. You got it, thanks for your input ! Thomas
									        Spiros
								                - Posts 1,088
										    Thanks for the tip!!!!!! Sory Thomas. My knowledge is not as good!!!
									        Thomas
								                - Norway
								                - Posts 85
										    Well, I have converted the files to AIFF, but still Beoport is not seeing them.  Am I missing some step here ?   Thomas
									        PhilLondon
								                - London
								                - Posts 2,545
										    have moved them in the correct directory? I do not have Beoport, so I am not sure what it needs to see them. Anyone? p.
									        BeoBoyLit
								                - Joined on 11-11-2007
								                - Posts 29
										      Thomas:Hi People, I have just gotten a beoport and I was wondering if there is a easy way to convert my Apple lossless files to something beoport understands (Without sacrify quality). Thomas
 Yes: convert to WMA lossless, you don't lose any quality, and works fine with beoport software. Beoport is only compatible with MP3, WMA, and WAV files.
									        Thomas
								                - Norway
								                - Posts 85
										    Hi, and thx for input all I will try WMA lossless Thomas
									        PhilLondon
								                - London
								                - Posts 2,545
										    A little bird told me that B&O will indeed recommand that we use WMA lossless. Not being a PC guy, can someone say if the standard Windows media Player can encode to WMA lossless? What is the approximate compression rate? p.
									        Puncher
								                - Joined on 03-27-2007
								                - Nr. Durham, NE England.
								                - Posts 9,588
										      wtlc2zpx: A little bird told me that B&O will indeed recommand that we use WMA lossless. Not being a PC guy, can someone say if the standard Windows media Player can encode to WMA lossless? What is the approximate compression rate? p.
 Compression rate is approx. 56% Windows Media player does indeed rip to WMA lossless.
        Page 1 of 1 (11 items)
