Latest post 11-02-2008 2:59 PM by Puncher. 10 replies.
Page 1 of 1 (11 items)
  • 10-26-2008 3:29 AM
    • Thomas
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Norway
    • Posts 85
    Convert Apple lossless
    Hi People,
    I have just gotten a beoport and I was wondering if there is a easy way to convert my Apple lossless files to something beoport understands (Without sacrify quality).
    Thomas
    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
  • 10-26-2008 3:52 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Convert Apple lossless
    Hi there.
    I guess this should be posted on the Mac/Apple section!!!
    Here it's good old PC forum!!!!!!!!!!!  Party!!!
    Best regards
    Spiros
  • 10-26-2008 4:30 AM In reply to
    spirost:
    Apple lossless is a codec in iTunes, the most commonly used media player on... PCs!
    Thomas seems to have a PC, as on a Mac, iTunes is used instead of Beoport, therefore he would not have to convert.
    Thomas,
    In iTunes, go to the preferences and in the Import section, chose the codec you want to convert the songs to. AIFF would convert it back to the original CD format, without losing any quality.
    Close the preferences, then select all the songs you want to convert and right click and select "Convert to AIFF".
    All the converted songs will be added to the library itself. Sort your library by "Date added" to separate the old versions from the newer versions.
    p.
  • 10-26-2008 5:00 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    p.
    You got it, thanks for your input !
    Thomas
  • 10-26-2008 5:03 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Thanks for the tip!!!!!!
    Sory Thomas. My knowledge is not as good!!!Ick!
    Best regards
    Spiros
  • 10-26-2008 10:29 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    Well, I have converted the files to AIFF, but still Beoport is not seeing them.  Am I missing some step here ?
    Thomas
  • 10-26-2008 11:05 AM In reply to
    have moved them in the correct directory?
    I do not have Beoport, so I am not sure what it needs to see them. Anyone?
    p.
  • 10-26-2008 11:15 AM In reply to
    Thomas:
    Hi People,
    Thomas
    Yes: convert to WMA lossless, you don't lose any quality, and works fine with beoport software.
    Beoport is only compatible with MP3, WMA, and WAV files.
  • 10-26-2008 2:46 PM In reply to
    • Thomas
    • Norway
    • Posts 85
    Hi, and thx for input all
    I will try WMA lossless
    Thomas
  • 10-31-2008 9:38 AM In reply to
    A little bird told me that B&O will indeed recommand that we use WMA lossless.
    Not being a PC guy, can someone say if the standard Windows media Player can encode to WMA lossless? What is the approximate compression rate?
    p.
  • 11-02-2008 2:59 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    wtlc2zpx:
    p.
    Compression rate is approx. 56%
    Windows Media player does indeed rip to WMA lossless.
