My beloved Beomaster 8000 now works like a dream, thanks to Dillen's excellent capacitor set and expert help with the displays.
Unfortunately, to my surprise yesterday the pushbuttons on the main control panel stopped working. There is no response at all, which made me think of a loose connector from the panel to the microprocessor board. Checked and double-checked the two connectors, but to no avails.
Other symptoms are: the pushbuttons under the aluminum cover don't respond anymore either (such as filters, and monitor). However, the volume and frequency control dials on the main panel work fine, as do the on-off switches under the aluminum cover (such as mono/stereo and loudness on/off). The remote control also still works fine, and the unit is a joy to listen to through the MS-150's.
Would anyone have a guess as to what could be the cause of this strange behaviour, or where to look for a way to fix it?
Thanks in advance for any suggestions!
September 2009 1st prize winner....
