Latest post 08-14-2008 5:15 AM by Hughie. 1 replies.
Page 1 of 1 (2 items)
  • 08-13-2008 3:13 PM
    • Hughie
    • Not Ranked
    • Joined on 04-17-2007
    • Walton-On-Thames
    • Posts 38
    Beomedia ir wiring to eye
    Dear friends
    I have my BM1 connected to my BV5 (first generation) using scart but now need to wire the ir cable into a eye - can anyone tell me where the Yellow, Brown & Green wires connect into the corresponding eye connections (my one has 5 slots) - currently have it connected as follows:
    • Yellow = 1
    • Green = 3
    • Brown = 5
    this I worked out from the wiring diagram off Beotech (http://www.beoworld.org/beotech/wiring4.htm)
    does anyone else have a similar set up that they could help me with the wiring
    Thanks, Hughie
    Filed under:
  • 08-14-2008 5:15 AM In reply to
    • Hughie
    • Not Ranked
    • Walton-On-Thames
    • Posts 38
    Re: Beomedia ir wiring to eye
    Ok - I seem to have solved the problem by moving the yellow wire into No4 and so the wires into the magic eye look as follows:
    •  Green = 3
    • Yellow = 4
    • Brown = 5
    all seems to be working now - just need to change the scart connections from v.aux to run off the PC command on the Beo4
