Dear friends
 I have my BM1 connected to my BV5 (first generation) using scart but now need to wire the ir cable into a eye - can anyone tell me where the Yellow, Brown & Green wires connect into the corresponding eye connections (my one has 5 slots) - currently have it connected as follows:
- Yellow = 1
- Green = 3
- Brown = 5
this I worked out from the wiring diagram off Beotech (http://www.beoworld.org/beotech/wiring4.htm)
does anyone else have a similar set up that they could help me with the wiring
Thanks, Hughie
