Latest post 12-27-2008 1:31 PM by Quim43. 54 replies.
Page 3 of 3 (55 items) < Previous 1 2 3
  • 12-27-2008 12:06 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Bugs in SW 1.32a ?!
    Is not that easy Sad
    There is a site called Remote Central where you can find lots of ccf files with codes of devices. What brand and model is your DVD?
    Once you have the ccf file, you have to take the HEX codes, convert them with the software of Lintronic and create one txt file for every command. When you have all commands created, you can make an xml file with a software created by Weebyx and Keith Sanuders, from the forum. This xml file is what you need to control your device with the Beo5.
    Quim
  • 12-27-2008 12:20 PM In reply to
    first i have to say sorry for my stupid questions.
     i was on the remote control site but i didn´t find any files there. where do i find the program to create the xml file?
    the tv i will control is a fujitsu siemens myrica v40 and the sat receiver is a kathrein ufs 301i.
  • 12-27-2008 12:40 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    First, there aren't stupid questions, only questions you don't know the answer (Keith told this to me Wink )
    Another way to have the codes is, if you have the original remotes, capturing the codes with a PDA.
    Please, read this thread.
    Quim
  • 12-27-2008 1:16 PM In reply to
    mhhh, i do not own a pda. i remember, that i can take ir signals with my logitech harmony, but i do not know if the program gives me the ir codes. maybe i should try this...
  • 12-27-2008 1:31 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You too can send a mail asking for the HEX codes to Fujitsu Siemens and Kathrein. Some people don't mind to give you the codes.
    Quim
