Is not that easy
There is a site called Remote Central where you can find lots of ccf files with codes of devices. What brand and model is your DVD?
Once you have the ccf file, you have to take the HEX codes, convert them with the software of Lintronic and create one txt file for every command. When you have all commands created, you can make an xml file with a software created by Weebyx and Keith Sanuders, from the forum. This xml file is what you need to control your device with the Beo5.
Quim
first i have to say sorry for my stupid questions.
i was on the remote control site but i didn´t find any files there. where do i find the program to create the xml file?
the tv i will control is a fujitsu siemens myrica v40 and the sat receiver is a kathrein ufs 301i.
First, there aren't stupid questions, only questions you don't know the answer (Keith told this to me )
Another way to have the codes is, if you have the original remotes, capturing the codes with a PDA.
Please, read this thread.
