So it looks like the firmware files in the firmware folder is update due to the different dates..
Would anybody with firmware 1.34a please try and mail me the files?
EDIT:
The "Beo5CT.exe.config" is also needed.
Here is my a snip of my .config file:
<appSettings>
<add key="WebConnected" value="y" />
<add key="LanguageDealer" value="English" />
<add key="CTVersion" value="1.30" />
<add key="SetupMenuLangSyncron" value="true" />
<add key="AppRestarterPath" value="AppStarter" />
<add key="Beo5Usb.inf" value="1.1.12.0" />
<add key="Beo5Usb.sys" value="1.1.12.0" />
<add key="Beo5RevE.bin" value="1.30a" />
<add key="Beo5RevF.bin" value="1.30a" />
<add key="Beo5RevD.bin" value="1.30a" />
</appSettings>
So as you can see the firmware is also defined in this XML document.
We will have to do some more testing to see if other files are needed.
