Latest post 12-27-2008 1:31 PM by Quim43. 54 replies.
Page 1 of 3 (55 items) 1 2 3 Next >
  • 06-26-2008 9:46 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Bugs in SW 1.32a ?!
    Does anyone else also have problems with the new SW 1.32a?
    The battery of the Beo5 doesn't last very long anymore...
    and look at this German thread: http://forum.beoworld.org/forums/125446/ShowThread.aspx#125446
  • 06-26-2008 10:11 AM In reply to
    Re: Bugs in SW 1.32a ?!
    I have the same problem, it's drainning the battery. But I only have software version 1.30a. Are you sure it's 1.32a?
    /Frank
  • 06-26-2008 10:42 AM In reply to
    The latest firmware update is 1.32a. The firmware is what is loaded into the Beo5.
    The Configuration software remains at version 1.30
    Regards Keith....
  • 06-26-2008 10:47 AM In reply to
    My Beo5 says: 1.30a, got it last week.
    /Frank
  • 06-26-2008 1:33 PM In reply to
    • Doc
    • Posts 585
    Are there solutions for the battery problem?
    Or do we have to wait for another update........?!
  • 06-30-2008 3:41 PM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Hi, the problem should be solved in the SW released today or tommorow, i talked to B&O today, since i found a bug in SW 1.32a. The bug was that if you only changed the volume and then set the remote down, the display would not turn of until you pressed a button other than the volume slider.
     I am having mine upgraded tommorow, so looking forward to that.
    /weebyx
  • 06-30-2008 4:15 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Weebyx:
    /weebyx
    I thought I was the only one that had this problem. At least, it's not my Be5 fault. Another bug is happenning with mine: if I press the Left or Right button on Stand menu, light comes down and it turns on again to stay on till i press another button.
    Quim
  • 07-01-2008 5:31 AM In reply to
    firmware version 1.34 has been released.... solving mentioned problems.
    Will be downloaded into the Beo5 Config tool when logged in to the Bang & Olufsen retail/dealer site and installed into the Beo5 during serialization.
  • 07-01-2008 1:14 PM In reply to
    • Doc
    • Posts 585
    Is there also a change in the configtool (now 1.30)?
  • 07-02-2008 12:50 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Doc:
    Is there also a change in he configtool (now 1.30)?
    Nope.
    Quim
  • 07-03-2008 9:37 AM In reply to
    jeroenv:
    Well, that's a problem for me. I can't login to the Bang & Olufsen retail/dealer site.
    Question: when I copy the files from the 'Bang & Olufsen\Beo5 Configuration Tool\Firmware\' directory from my dealer (after he has download the firmware once) and put the files on my PC. Will that do the job for firmware version 1.34?
    Piet
  • 07-03-2008 11:05 AM In reply to
    • Doc
    • Posts 585
    Good question! Wondering about that to....
  • 07-04-2008 7:07 AM In reply to
    Doc,
    When I have the newest firmware I will put my results here.
    First I have to find it.
    Piet
  • 07-04-2008 8:22 AM In reply to
    Hello Piet,
    never tried this before. Should work in theory.....
    groetjes
    Jeroen
  • 07-04-2008 5:02 PM In reply to
    • Doc
    • Posts 585
    Piet van der Zalm:
    jeroenv:
    Piet
    So if I understand correctly, you want to change your current five "1.30 / 1.32" .bin-files from the Firmware-directory , for the "1.34" .bin-files you get from your dealer?
  • 07-05-2008 3:29 AM In reply to
    And some other files. Only the bin-files is not enough. I think its possible.
    Piet
  • 07-05-2008 3:43 AM In reply to
    • Doc
    • Posts 585
    Piet van der Zalm:
    Piet
    Do you know which other files are needed?
  • 07-05-2008 4:49 AM In reply to
    Doc,
    I am busy with it.
    Besides the firmware directory I think the Beo5ct.exe.config, both serialize files and maby the Beo5ct.xmlserializers.dll
    What would help is a directory listing of the ../Bang & olufsen/Beo5 configuration tool and the firmware directory from someone who has firmware 1.34 installed (with filenames, size and time stamp).
    Who has it??????  Sent it to me, please!!
    Piet
  • 07-05-2008 12:30 PM In reply to
    • Doc
    • Posts 585
    Yes, please send it to him!Wink
  • 07-05-2008 1:51 PM In reply to
    • ujn2
    • Not Ranked
    • Joined on 03-27-2008
    • Posts 17
    Somebody please provide us with the firmware files. I'm also having the battery problem... As soon as i plug it out it says "Recharge battery"
  • 07-05-2008 2:02 PM In reply to
    • Doc
    • Posts 585
    Yes, have that problem to: battery doesn't last very long............
  • 07-06-2008 7:13 AM In reply to
    Tell me where to find the firmware in the Beo5 file, and I will extract it. I couldn't find it in the firmware file - it seems to go directly onto the Beo5 when it is attached to the dealer site.
  • 07-06-2008 7:27 AM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    I thought that when you are connected it downloads the firmware to the folder named "Firmware" inside the installation folder?
    Here's a screenshot from my Firmware folder... (Config tool v1.30)
  • 07-06-2008 9:28 AM In reply to
    If the firmware is not downloaded to the firmware directory, than we have a problem to get it.
    If so, the dealer cannot do updates offline (at the customers site with his laptop).
     Piet
  • 07-06-2008 9:51 AM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    Please everybody with new firmware releases post some pictures of your firmware folder in the installation folder.
