Latest post 12-27-2008 1:31 PM by Quim43. 54 replies.
Page 2 of 3 (55 items) < Previous 1 2 3 Next >
  • 07-06-2008 10:26 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Bugs in SW 1.32a ?!
    This is my folder. I updated the firmware and the configuration on July 1th, connected to the B&O server.
    Quim
  • 07-06-2008 12:56 PM In reply to
    • ujn2
    • Not Ranked
    • Joined on 03-27-2008
    • Posts 17
    So it looks like the firmware files in the firmware folder is update due to the different dates..
    Would anybody with firmware 1.34a please try and mail me the files?
    EDIT:
    The "Beo5CT.exe.config" is also needed.
    Here is my a snip of my .config file:
      <appSettings>
        <add key="WebConnected" value="y" />
        <add key="LanguageDealer" value="English" />
        <add key="CTVersion" value="1.30" />
        <add key="SetupMenuLangSyncron" value="true" />
        <add key="AppRestarterPath" value="AppStarter" />
        <add key="Beo5Usb.inf" value="1.1.12.0" />
        <add key="Beo5Usb.sys" value="1.1.12.0" />
        <add key="Beo5RevE.bin" value="1.30a" />
        <add key="Beo5RevF.bin" value="1.30a" />
        <add key="Beo5RevD.bin" value="1.30a" />
      </appSettings>
    So as you can see the firmware is also defined in this XML document.
    We will have to do some more testing to see if other files are needed.
  • 07-06-2008 3:12 PM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    I'm still a bit puzzled: When hooking up a Beo5 to the dealer network, the firmware of the Beo5 is upgraded to 1.34 and also there's a change of the configtool (at least 3 bin-files of the Firmware-directory change). So far, so good.
    But how can we upgrade our Beo5 by only just changing our configtool? A changed configtool can't "send" a new firmware to the Beo5, or can it?!
  • 07-07-2008 4:42 AM In reply to
    Yes doc, it can.
    I think that when the serialisation proces is started the program wil compare the firmware level in the BEO5 with the level described in de Beo5CT.exe.config. If it is not the same then the firmware files from the PC are transferred to the BEO5.
    This is my guess how it works.
    Piet
  • 07-07-2008 7:50 AM In reply to
    • Doc
    • Posts 585
    Sounds good Piet, hope it works!
    Let us know if you managed to get it working.
  • 07-12-2008 5:20 AM In reply to
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    yes, it should work this way but how do we get the files and what files do we have to get exactly. If somebody can tells me exactly which files the dealer needs to copy I should be able to sort that out. Of course all that only makes sense if we know how to implement?
    Best regards Oliver
  • 07-12-2008 5:36 AM In reply to
    You need the Beo5CT.exe.config and the files from the firmware directory. Thats all.
    Put the files on your PC (overwrite the existing files) and start the serialization. The new firmware will be loaded.
  • 12-08-2008 11:50 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Did someone ever get their 1.30 tool to update firmware to 1.34a offline ?
     /Weebyx
  • 12-08-2008 3:08 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Weebyx:
     /Weebyx
    A member from Spanish Beoworld did it.
    Quim
  • 12-08-2008 3:22 PM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    Quim43:
    Weebyx:
     /Weebyx
    Also got it working, just replaced the 5 files in the firmware lib, and changing the beoconfig.exe.xml file from 1.30a to 1.34a,
    /Weebyx
  • 12-08-2008 3:48 PM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    That is not enough.
    That will not give you the full 1.34a firmware - there are still some things missing.
  • 12-08-2008 4:07 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You need to edit the Beo5CT.exe.config and change these values:
        <add key="Beo5RevE.bin" value="1.34a" />
        <add key="Beo5RevF.bin" value="1.34a" />
        <add key="Beo5RevD.bin" value="1.34a" />
    Quim
  • 12-08-2008 4:23 PM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    Quim43:
    That will not be enough, you will still be missing some features when using this method.
  • 12-09-2008 12:55 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    ujn2:
    That is not enough.
    Aha, what is missing, the remote says 1.34a as firmware release when i look in the service menu, and the 3rd party support is also working?
    /Weebyx
  • 12-09-2008 2:11 AM In reply to
    Weebyx has got his Beo5 updated correctly including the configuration file.
    Regards Keith....
  • 12-09-2008 3:02 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    Keith Saunders:
    Yes, and thanks to Keith for helping with info :)
     /Weebyx
  • 12-09-2008 4:08 AM In reply to
    • santi
    • Joined on 12-08-2007
    • Barcelona
    • Posts 170
    I updated as well and everything looks to work properly. Thanks to Quim as well for the info.
    In addition it solves a bug I had with software 1.30a (I did not see any reference about it).
    The bug is related to the following: if you configure the Beo5 with a third party accessory like Lutron Rania IR, after using one of the Lutron codes, the Beo5 IR Power range gets reduced, so you need to point directly to the equipment IR receiver. This continues to happen until you power off and on the Beo5, then works properly until you press any of the Lutron commands again. This does not only happen with lutron codes, I think it happens when you use a non B&O IR code.
    Santi
  • 12-09-2008 4:50 AM In reply to
    I'm full controlling now 5 non-B&O devices (Philips, Thomson, Sony, Panasonic and Pinnacle) directly with the Beo5, and of course thanks to Keith's XML generator tool and his help info procedure... the beo5 works very well in all cases Yes -  thumbs up
    but here is the difference with the majority of beo5 users: I'm still using the Beo5ConfigTool 1.02 with Serializer version 0.35, and my Beo5 still has the 1.20a firmware... Embarrassed  and NO bugs however !!!   the 3rd party support is also working perfectly well.
    Everything works correctly, but I've not upgrade the Beo5 firmware to 1.34a yet, and I'm not using the 1.30 Beo5ConfigTool Ick!
    Santiago
  • 12-09-2008 4:51 AM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    Weebyx:
    ujn2:
    That is not enough.
    /Weebyx
    I'm not sure, but I did also update my Beo5 like this when the 1.34a was released. However I was missing full support for the Lintronic box - so I could not use the CNTL_X and FUNCTION_X until I did a get update from a "online" Beo5 config tool.
  • 12-27-2008 6:44 AM In reply to
    hey guys,
    can you give me a little howto how i can get the new firmware files offline?
    or do i only have to change the values in the beo5ct.exe?
  • 12-27-2008 6:57 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You need some files to change in the firmware folder. Send me a PM with your mail adress and I will send them to you. Then, you need to change some values like it was explained before.
    Quim
  • 12-27-2008 8:32 AM In reply to
    thanks! you got pm :-)
  • 12-27-2008 9:33 AM In reply to
    firmware 1.34 work for me just fine!
    but i can´t control my sat receiver. when i´m in the living room, where its connectet with the bv7 it works. but if i go in the celler, where the receiver is, the remote doesn´t work. my other non b&o sat receiver in a other room doesn´t work too.
    the only non b&o product that work is the apple remote, but not correctly. what do i wrong? is it possible to get my non b&o devices to work?
  • 12-27-2008 10:40 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    If you want control your sat receiver directly from your Beo5, without IR transmitter, you have to create an xml file with the codes of your sat receiver. Maybe you are controlling it now because it is in the PUC list of your BV7.
    Quim
  • 12-27-2008 11:39 AM In reply to
    where do i get the codes from? i tried the standert generic file, but thats not individual and so it doesn´t work.
