THE ANSWER TO MY REQUEST
Dear Mr. H
We are pleased to see that you are the owner of several Bang & Olufsen products. The setup you described is not possible, as you cannot do this with datalink cables. You will need to use Masterlink cables.
Kind regards
Bang & Olufsen a/s
Christian Nielsen
BeoCare
MY REQUEST:
I upgraded my BV 3-32 to a BV 4-50 + BeoLab10. Now, I'm having a problem with my old Datalink cable.
My BV 3-32 was linked through a BeoLink Video Converter and Datalink cable and a coax cable to a MX 5500.
Now, I want to link the BV 4-50 with the BV3-32. I know that this usually is done by the Masterlink cable.
Unfortunally, I can't replace the old Datalink cable with a Masterlink cable so I have to stay with the Datalink + coax cable.
Now the question: Is there any possibility to link the BV 4-50 with the BV 3-32 through a datalink cable (7 pins) and a coax cable, like it worked perfectly before ???
Can I use for example a second BeoLink Converter to convert from Datalink again to Masterlink? Does the Beolink Video Converter work in both ways?
=> Masterlink in the mainroom -> Beolink Video-> Datalink -> linkroom Beolink Video converter-> Masterlink -> BV3. Coax connected as usual.
RESULT:
so I had to test this by my own: the described setup with the datlink cable works perfectly!
This was my first request to the B&O support during the last 20 years. Is this the usual quality of the responses?
BTW: Thanks to this wonderful forum: after downloading the installation manual for Beomedia1, the configuration was done by fly...
Claus
