Latest post 04-24-2008 11:23 AM by soundproof. 4 replies.
Page 1 of 1 (5 items)
  • 04-24-2008 5:23 AM
    • wendigo
    • Not Ranked
    • Joined on 04-21-2008
    • Munich
    • Posts 12
    B&O support
    THE ANSWER TO MY REQUEST
    Dear Mr. H
    We are pleased to see that you are the owner of several Bang & Olufsen products. The setup you described is not possible, as you cannot do this with datalink cables. You will need to use Masterlink cables.
    Kind regards
    Bang & Olufsen a/s
    Christian Nielsen
    BeoCare
    MY REQUEST:
    I upgraded my BV 3-32 to a BV 4-50 + BeoLab10. Now, I'm having a problem with my old Datalink cable.
    My BV 3-32 was linked through a BeoLink Video Converter and Datalink cable and a coax cable to a MX 5500.
    Now, I want to link the BV 4-50 with the BV3-32. I know that this usually is done by the Masterlink cable.
    Unfortunally, I can't replace the old Datalink cable with a Masterlink cable so I have to stay with the Datalink + coax cable.
    Now the question: Is there any possibility to link the BV 4-50 with the BV 3-32 through a datalink cable (7 pins) and a coax cable, like it worked perfectly before ???
    Can I use for example a second BeoLink Converter to convert from Datalink again to Masterlink? Does the Beolink Video Converter work in both ways?
    => Masterlink in the mainroom -> Beolink Video-> Datalink -> linkroom Beolink Video converter-> Masterlink -> BV3. Coax connected as usual.
    RESULT:
    so I had to test this by my own: the described setup with the datlink cable works perfectly!
    This was my first request to the B&O support during the last 20 years. Is this the usual quality of the responses?
    BTW: Thanks to this wonderful forum: after downloading the installation manual for Beomedia1, the configuration was done by fly...
    Claus
  • 04-24-2008 5:46 AM In reply to
    Re: B&O support
    Perhaps they did'nt know wether this is possible and never tried ? so now If someone [else] asks B&O questions about MCL / ML combinations they certainly will suggest not to ask Christian but ask Claus..................Wink
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 04-24-2008 5:52 AM In reply to
    Re: B&O support
    Claus,
    Unfortunately, the response you received is not unusual, which is a considerable pity, given the general quality of B&O products.
    Nevertheless, your tests prove that this is a valid configuration and maybe useful to other members in the future.
    Thank you for taking the time to provide this feedback.
    Regards Keith....
  • 04-24-2008 10:00 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: B&O support
    Congratulations Claus,
    I thought it should be possible. It´s great that people are trying setups (successfully) that Beo do not support and post their experiences here on Beoworld. Thanks for that.
    Stefan
  • 04-24-2008 11:23 AM In reply to
    Re: B&O support
    Congrats Claus,
    I'm afraid I'm going to have to agree with Keith here. You don't have to spend long on the official B&O site, following the threads with questions from customers, to understand that B&O support is sloooooow & often wroooooong when it comes to what can or can't be done with their equipment.
    That was some smart lateral thinking you carried out there! I'll make a note of it - not in need of it now, but could come in handy.
