Sounds like the old spindle motor problem. Did you let the unit get up to room temperature first?
If it still doesnt work, you'll have to take the motor apart, clean the old lube, and reapply fresh. I used '3 in 1' oil on mine, and its been fine for over two years now.
Cheers,
Ben.
