Can anyone identify this motor ?It's apprx 60mm (6cm) in diameter, housing is apprx 26mm high.Spindle is apprx 5mm diameter. It's a 14VDC motor with a 2-pin connector on a cable.I believe it's used in some newer (post-1990) B&O machines but which one(s) and for what ?
Hello
I opened a CD 650 and found a very similar motor on the cd (drawer) loading mechanism, diameter and height are similar (I haven't dismounted...).
Hope this helps
ciao ciao
Eugenio Colazzo
I take it that you mean a CD6500.
Thanks, that could be one place it fits, maybe it will fit other places.
Martin,greetings.I think it might be a sledge motor for the Beosound 9000.A very hard working item!
Regards,
Nick
Dillen:I take it that you mean a CD6500.Thanks, that could be one place it fits, maybe it will fit other places.Martin
I mean a Philips CD 650
Thanks, guys.
Yes, it's way too large to fit in a Beogram CD6500. Maybe the Philips player.
A Beosound 9000 sledge motor sounds more like it.
It is a sledge motor from a Beosound 9000. No question.
I believe they were also used as disc motors in laserdisc players.
You guys blow me away with your knowledge !!!!
Poor me, never win owt!
Thanks for the input Cozza !
Well, I have a couple of these motors, brand new.
Jandyt, maybe if you'll let us know about what size it is ?
Jandyt:It's phenomenal the ammount of knowledge available on tap on Beoworld.Between the 4631 of us, there's not much we don't know!Funny though, nobody seemed to know what this was.
Hmm, Is it a false nail on one of your jumpers that has bits of haystack embedded in it?
Ring a bell?
If you think nobody cares, try missing a couple of payments.
Gosh, you lt have got poor memories!!!
Andy T.
Thanks, definitely not the same.
