Latest post 01-22-2008 12:40 PM by Dillen. 14 replies.
Page 1 of 1 (15 items)
  • 01-09-2008 8:34 AM
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Can anyone identify this motor ?
    It's apprx 60mm (6cm) in diameter, housing is apprx 26mm high.
    Spindle is apprx 5mm diameter. It's a 14VDC motor with a 2-pin connector on a cable.
    I believe it's used in some newer (post-1990) B&O machines but which one(s) and for what ?
  • 01-10-2008 5:24 AM In reply to
    Re: Can anyone identify this motor ?
    Hello
    I opened a CD 650 and found a very similar motor on the cd (drawer) loading mechanism,  diameter and height are similar (I haven't dismounted...).
    Hope this helps
    ciao ciao
    Eugenio Colazzo
  • 01-10-2008 6:08 AM In reply to
    • Dillen
    • Posts 5,008
    I take it that you mean a CD6500.
    Thanks, that could be one place it fits, maybe it will fit other places.
  • 01-10-2008 7:28 AM In reply to
    Martin,greetings.I think it might be a sledge motor for the Beosound 9000.A very hard working item!
    Regards,
    Nick
  • 01-10-2008 8:54 AM In reply to
    Dillen:
    I mean a Philips CD 650
    Eugenio Colazzo
  • 01-10-2008 11:47 AM In reply to
    • Dillen
    • Posts 5,008
    Thanks, guys.
    Yes, it's way too large to fit in a Beogram CD6500. Maybe the Philips player.
    A Beosound 9000 sledge motor sounds more like it.
  • 01-16-2008 4:34 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    It is a sledge motor from a Beosound 9000. No question.
     I believe they were also used as disc motors in laserdisc players.
  • 01-16-2008 4:41 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    You guys blow me away with your knowledge !!!!
    IndifferentSmile
  • 01-16-2008 5:03 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    It's phenomenal the ammount of knowledge available on tap on Beoworld.
    Between the 4631 of us, there's not much we don't know!
    Funny though, nobody seemed to know what this was.
    Poor me, never win owt!
  • 01-16-2008 6:47 PM In reply to
    • Dillen
    • Posts 5,008
    Thanks for the input Cozza !
    Well, I have a couple of these motors, brand new.
    Jandyt, maybe if you'll let us know about what size it is ?
  • 01-17-2008 5:16 AM In reply to
    • cozza
    • New Zealand
    • Posts 119
    You'll be pleased to know that they hardly ever fail. Unless a 110V Beosound 9000 is accidentally plugged into 230V, that is.
  • 01-17-2008 10:26 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Jandyt:
    Hmm, Is it a false nail on one of your jumpers that has bits of haystack embedded in it?
    Ring a bell?Stick out tongue
    If you think nobody cares, try missing a couple of payments.
  • 01-17-2008 6:39 PM In reply to
    • Jandyt
    • Posts 13,004
    Gosh, you lt have got poor memories!!!
    Andy T.
  • 01-22-2008 11:30 AM In reply to
    • PL212
    • Top 200 Contributor
    • Moderator - Seattle
    • Posts 318
    Here's the motor of a BC9500 in situ for comparison:
  • 01-22-2008 12:40 PM In reply to
    • Dillen
    • Posts 5,008
    Thanks, definitely not the same.
