1st March February 2012
Latest post 01-22-2008 12:40 PM by Dillen. 14 replies.
01-09-2008 8:34 AM
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Can anyone identify this motor ?
Can anyone identify this motor ? It's apprx 60mm (6cm) in diameter, housing is apprx 26mm high. Spindle is apprx 5mm diameter. It's a 14VDC motor with a 2-pin connector on a cable. I believe it's used in some newer (post-1990) B&O machines but which one(s) and for what ? Martin
Eugenio Colazzo
- Joined on 07-02-2007
- Italy - Terni
- Posts 168
Re: Can anyone identify this motor ?
Hello I opened a CD 650 and found a very similar motor on the cd (drawer) loading mechanism, diameter and height are similar (I haven't dismounted...).
Hope this helps ciao ciao
Dillen
- Posts 5,008
I take it that you mean a CD6500. Thanks, that could be one place it fits, maybe it will fit other places. Martin
solderon29
- Joined on 06-24-2007
- Posts 235
Martin,greetings.I think it might be a sledge motor for the Beosound 9000.A very hard working item! Regards, Nick
Eugenio Colazzo
- Italy - Terni
- Posts 168
Dillen: I take it that you mean a CD6500. Thanks, that could be one place it fits, maybe it will fit other places. Martin
I mean a Philips CD 650
Dillen
- Posts 5,008
Thanks, guys. Yes, it's way too large to fit in a Beogram CD6500. Maybe the Philips player. A Beosound 9000 sledge motor sounds more like it. Martin
cozza
- Joined on 04-17-2007
- New Zealand
- Posts 119
It is a sledge motor from a Beosound 9000. No question. I believe they were also used as disc motors in laserdisc players.
9 LEE
- Moderator - UK
- Posts 5,223
You guys blow me away with your knowledge !!!!
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
It's phenomenal the ammount of knowledge available on tap on Beoworld. Between the 4631 of us, there's not much we don't know! Funny though, nobody seemed to know what this was.
Dillen
- Posts 5,008
Thanks for the input Cozza ! Well, I have a couple of these motors, brand new. Jandyt, maybe if you'll let us know about what size it is ? Martin
cozza
- New Zealand
- Posts 119
You'll be pleased to know that they hardly ever fail. Unless a 110V Beosound 9000 is accidentally plugged into 230V, that is.
Stonk
- Joined on 04-16-2007
- Marlow, Bucks, UK
- Posts 1,688
Jandyt: It's phenomenal the ammount of knowledge available on tap on Beoworld. Between the 4631 of us, there's not much we don't know! Funny though, nobody seemed to know what this was.
Hmm, Is it a false nail on one of your jumpers that has bits of haystack embedded in it? Ring a bell?
If you think nobody cares, try missing a couple of payments.
PL212
- Moderator - Seattle
- Posts 318
Here's the motor of a BC9500 in situ for comparison:
Dillen
- Posts 5,008
Thanks, definitely not the same. Martin
Page 1 of 1 (15 items)
