Latest post 01-03-2008 4:14 PM by stefan. 6 replies.
Page 1 of 1 (7 items)
  • 12-17-2007 6:51 PM
    Beo5 Configuration on a Mac
    Have any Mac users had experiences (good or bad) with using the Beo5 Configuration Software on a Mac by way of Windows running on Virtual PC?
  • 12-18-2007 3:40 AM In reply to
    Re: Beo5 Configuration on a Mac
  • 12-18-2007 4:38 AM In reply to
    It does not work with VM Ware for me... the sofware runs but cannot "see" the remote on the USB.
     p.
  • 12-18-2007 5:23 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    works great on my Mac Book with Parallels Desktop 3.0, also USB connection works without problems.
    Stefan
  • 12-18-2007 6:21 AM In reply to
    Thanks for your feedback guys!
    I know that when configuring the Lintronic device on Virtual PC, it was a little tricky to get Windows to recognize the cable, but with some adjustments to Windows it could be done.
  • 01-02-2008 4:13 PM In reply to
    stefan:
    Stefan
    Hi Stefan!
    Did you do anything special to make this work?
    XP Pro?
    What version of the config soft did you use?
    Best Regards
    Ola
  • 01-03-2008 4:14 PM In reply to
    • stefan
    • Posts 1,733
    Hi Ola,
    no, nothing special. Windows XP Home, Config Tool 1.00, Serialiser Vers. 0.35. Because of USB connection issues I had to update Parallels Desktop to 3.0. Beo 5 must be powered off before being placed into the charger. Hope this helps.
    Regards
    Stefan
