http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
It does not work with VM Ware for me... the sofware runs but cannot "see" the remote on the USB.
p.
Mac, iPad & iPhone Apps: Beoworld, LinkPlayer, LinkRemote, Story Mouse, The Emperor's New Clothes
Thanks for your feedback guys!
I know that when configuring the Lintronic device on Virtual PC, it was a little tricky to get Windows to recognize the cable, but with some adjustments to Windows it could be done.
stefan:works great on my Mac Book with Parallels Desktop 3.0, also USB connection works without problems.Stefan
Hi Stefan!
Did you do anything special to make this work?
XP Pro?
What version of the config soft did you use?
Best Regards
Ola
Hi Ola,
no, nothing special. Windows XP Home, Config Tool 1.00, Serialiser Vers. 0.35. Because of USB connection issues I had to update Parallels Desktop to 3.0. Beo 5 must be powered off before being placed into the charger. Hope this helps.
Regards
Stefan
