Latest post 11-28-2007 6:32 PM by Santiago. 37 replies.
Page 2 of 2 (38 items) < Previous 1 2
  • 11-18-2007 12:52 PM In reply to
    Re: Picture format changing up/down arrows
    Stefan you've solved 2 of the 3 problems I had with my beo5 !!!!!! Yes -  thumbs up
    The third problem (relating some Beo5 hard keys) is explained with detail from here on
    Do you have any idea? Smile
    Thank you in advance.
    Santiago
  • 11-18-2007 2:05 PM In reply to
  • 11-18-2007 2:19 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Welcome to the forum BeoBoy Lit.Big Smile
    Try not to be too shy.Wink
    Andy T.
    Poor me, never win owt!
  • 11-18-2007 3:21 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Sorry, I have no HDR2. But I have borrowed one from my dealer and programmed 2 soft keys: 0:000:VTR:CNTL_WIND and....REWIND (yellow and green) with arrows left/right. It`s exactly what you did. Should also work with hard keys..(?).I have some hard keys reconfigured using a STB including macros. Works great. Maybe you could try to change the adress: 0:000:TV:CNTRL_WIND ....REWIND..but I don`t really know. Good Luck Stefan
  • 11-19-2007 4:35 AM In reply to
    stefan:
    I have borrowed one from my dealer and programmed 2 soft keys: 0:000:VTR:CNTL_WIND and....REWIND (yellow and green) with arrows left/right. It`s exactly what you did. Should also work with hard keys..(?)...Maybe you could try to change the adress: 0:000:TV:CNTRL_WIND ....REWIND..but I don`t really know. Good Luck Stefan
    No luck here Stefan Sad
    I tried long time ago the on-screen buttons and those worked well, but I want to use the Beo5 "<<" ">>" hard keys for a quick "blind" daily use.
    Unfortunately I've tried all the combinations using "TV""VTR""WIND/REWIND""CNTL_WIND/REWIND"...with no success at all Sad
    It seems like if those two hard keys inside the VTR (HDR2) section doesn't admit any "reconfiguration" via software and always work as "previous""next" commands Hmm
    However, inside the CD section this software reconfiguration works very well Unsure and the beo5 "<<"">>" hard keys function now as "rewind""wind" for the BS9000 (no more as "previous""next") Yes -  thumbs up
    Regards.
    Santiago
  • 11-28-2007 6:39 AM In reply to
    Hello everyone,
    I need HELP AGAIN! I've troubles to configure my beo5 Confused
    It's a similar problem than before, about using the 4 arrows control inside a command Angry
    I cannot do work BALANCE or FADE options with my beo5 Sad (hard keys or screen keys)
    With Beo4 I use the 4 key arrows inside the SPEAKER command  to control those options... but after several attempts I don't know how configure the correct IR code keys in Beo5 to achieve these functions Hmm
    Thanks in advance for any help.
    Santiago
  • 11-28-2007 3:57 PM In reply to
    • stefan
    • Posts 1,733
    Choosing BV7 as product will create a button "Speaker..." incl. submenu with mode 1 - 5 and a button "Balance". Pressing "Balance" will open a submenu with 4 buttons: Arrow up/down and arrow left/right. These should control the functions you are looking for.
    Good Luck.
    Stefan
  • 11-28-2007 4:39 PM In reply to
    • Jandyt
    • Posts 13,004
    Stefan, Which model of BV7 should be used? I tried it before with the picture format question but couldn't get what you described.
    Andy T.
  • 11-28-2007 5:09 PM In reply to
    • stefan
    • Posts 1,733
    Hi Andy, I have a BV7 MK II and audiomaster is BS 9000. Did you try to get the "Picture"-button? I think, it did work for Santiago... (?)
    Stefan
  • 11-28-2007 5:19 PM In reply to
    • Jandyt
    • Posts 13,004
    I have to tell mine that I have an Ouverture or I won't get tape commands for my Beosystem 7000.
    I wonder if it's something to do with that. I'll try again when I get the time.
    Andy T.
  • 11-28-2007 6:20 PM In reply to
    Hi Andy, I had explained that here
    and here specifically for you!! Big Smile
    Read the two last lines (PD)...Wink
    Santiago
  • 11-28-2007 6:28 PM In reply to
    • Jandyt
    • Posts 13,004
    Cheers my friend. Time for another little play I think.
    In my Client file I am saving lots of different configurations by adding a letter to my serial number.
    That way, I can revert to a previously stored config.
    Andy T.
  • 11-28-2007 6:32 PM In reply to
    Laughing
    My beo5 counter shows: Config. Download (times): 134!!! Laughing
    to be continued...
    Santiago
