stefan: I have borrowed one from my dealer and programmed 2 soft keys: 0:000:VTR:CNTL_WIND and....REWIND (yellow and green) with arrows left/right. It`s exactly what you did. Should also work with hard keys..(?)...Maybe you could try to change the adress: 0:000:TV:CNTRL_WIND ....REWIND..but I don`t really know.
Good Luck
Stefan
No luck here Stefan
I tried long time ago the on-screen buttons and those worked well, but I want to use the Beo5 "<<" ">>" hard keys for a quick "blind" daily use.
Unfortunately I've tried all the combinations using "TV""VTR""WIND/REWIND""CNTL_WIND/REWIND"...with no success at all
It seems like if those two hard keys inside the VTR (HDR2) section doesn't admit any "reconfiguration" via software and always work as "previous""next" commands
However, inside the CD section this software reconfiguration works very well and the beo5 "<<"">>" hard keys function now as "rewind""wind" for the BS9000 (no more as "previous""next")
Regards.
