1st March February 2012
Latest post 11-16-2011 5:11 PM by sergi0. 21 replies.
04-20-2007 11:32 AM
Peter
- Joined on 02-12-2007
- Posts 9,572
Product Configuration Guide
Have you ever wondered how some members seem to be so clever and know everything about Masterlink? Do you too want to impress your fellow Beo enthusiast and make the girls faint at your prowess? Your chance is here! The Product Configuration Guide Software is available for download! Many thanks to Steve Boxall for trying out the link and to Puncher who thought of the idea ! For Gold and Silver members, go to the User and Service Guide section, and to Music Systems/Beolink Products/Product Configuration Guide Download the file and then change the last three letters from pdf to exe The software is a little temperamental - it is a B&O product! - but is extremely helpful. The only bad news is that it doesn't work on a Mac - so I cannot use it! Therefore you can all correct me when I get the answers wrong!
Peter
- Posts 9,572
Re: Product Configuration Guide
I people can confirm it works, I would be grateful!
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Peter is does not seem to be working. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Peter
- Posts 9,572
Strange! Had one reply that it was! Did you remove the pdf and replace it with a .exe - also try putting a space between Product, guide and configuration!
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Downloaded, installed and runs just fine - fancy that!
ouverture
- Joined on 04-20-2007
- London
- Posts 282
can confirm that it installs ( albeit a bit slowly ) and works on my Windows XP laptop, it is worth the effort, as it really does spell the config when using masterlink in different link rooms with different kit
Peter
- Posts 9,572
Have been told that this is an old version - can't check on a Mac so I am loading a newer one!
Tom
- Joined on 04-16-2007
- Luxembourg
- Posts 3,175
Installed and working. Could be usefull for the future. Thanks
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Corvin
- Australia
- Posts 124
No Beosystem 3 that i can find!
Tom
- Luxembourg
- Posts 3,175
i think this is an old version, there is no bl7, no bs4, and i thing there are many other products missing from the lists.
Peter
- Posts 9,572
I have put the newest there is on! There are now two - an old one which I will remove and the new version 2.54 . I cannot really help with these as they do not run on my Mac!
SteveB
- Posts 25
Thanks again Peter, have downloaded the updated version and installed it with no problems. By the way in case it helps other users I am running this on a laptop running XP SR2. Please let me know what problems others are having and I will certainly do my best to help Steve
sergi0
- Joined on 03-06-2011
- Posts 99
Hi Peter,
Is the software still available? I try to find it on the website but was unable to get it...
cheers,
sergio
RaMaBo
- Joined on 11-09-2011
- Munich / Germany
- Posts 8
sergi0:
Hi Peter,
cheers,
sergio
Hi sergi0,
i found the software here but i can't let it run, after installing it gives me an error stating that the win16 subsystem doesn't have enough ressources to run BOCONFIG. Click on OK and restart computer
The computer is 32Bit XP SP3 incl. all MS patches.
Maybe Peter or Keith have any hints for this problem?
Regards
Ralph-Marcus
My Beo: ... Beovision 3-32, BeoCenter 2500, BeoLab 8000, BeoLab 2000, BeoLink 1000, 5000, 4, LC2, BeoCom 6000 ISDN, BeoCom 2500, BeoTalk 1100, VDR (Linux based Twin-Sat Receiver), Teac WAP-4500 ((W)LAN Streaming Client with Internetradio), A8, A9 ...
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
RaMaBo:
I suppose you used the upper of the links (announced as "latest")?
Just
tried it on my laptop (32-bit Vista) and it works fine without any
tweaks, but you need to run the installer as administrator.
Obviously
the installer needs to finish without any errors. If it did, but you
still get the above error, you might try to run it in Win95
compatibility mode, or something...
The actual program seems to be
ancient (it's probably a 16-bit program predating even Win95!) and they
have just added a more modern installer and updated the product info. The user interface is terrible
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Downloaded, it works fine.
And I found a very interesting point, according to the "conclusion" thought only the TV show cheaters used that term...  The BV10 can provide Beolab 5's with source data in a masterlink setup with the Beolab 5's connected to the BV10, thus enabling them to listen for the spdif input when in speaker mode 2???
Anyone can confirm this?
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
bayerische
- Helsinki, Finland
- Posts 3,593
Sidenote, to get the program working I had to run the win2000 version.
-Andreas
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
I could install the program on my Win7 System without problems. But I cannot start it because it says it is not compatible. Seems windows requests a 32bit or 64bit version...
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
tournedos
- Finland
- Posts 5,808
Heribert:
If you have the 64-bit version of Windows 7, it will not natively run these old programs. It lacks the 16-bit subsystem completely.
You could install some virtual machine software, install some older version of Windows in that and try that way - but frankly, it isn't worth going through hoops just to run the PCG.
RaMaBo
- Munich / Germany
- Posts 8
I installed the newest version and it installed well without any errors but it gave me the mentioned error.
The problem was Win XP itself: After hibernating the machine the last 2-3 months and no restart during this time it was just time to boot the whole machine and tadaa! The Product Configuration Guide started well and run quite smooth but the user interface is really terrible [:'(]
Regards
RaMaBo
sergi0
- Posts 99
thanks a lot for the link I was not able to find... shame on me ;)
I confirm that you have to run a 32 bit OS in order to use this tool. I use it inside a virtual machine and it works well!
but... the interface is so 95!!!! incredible ;)
Page 1 of 1 (22 items)
