Latest post 11-16-2011 5:11 PM by sergi0. 21 replies.
Page 1 of 1 (22 items)
  • 04-20-2007 11:32 AM
    Yes -  thumbs up [Y] Product Configuration Guide
    Have you ever wondered how some members seem to be so clever and know everything about Masterlink? Do you too want to impress your fellow Beo enthusiast and make the girls faint at your prowess?
    Your chance is here! The Product Configuration Guide Software is available for download! Many thanks to Steve Boxall for trying out the link and to Puncher who thought of the idea !
    For Gold and Silver members, go to the User and Service Guide section, and to Music Systems/Beolink Products/Product Configuration Guide
    Download the file and then change the last three letters from pdf to exe
    The software is a little temperamental - it is a B&O product! - but is extremely helpful.
    The only bad news is that it doesn't work on a Mac - so I cannot use it! Therefore you can all correct me when I get the answers wrong!Laughing
  • 04-20-2007 12:55 PM In reply to
    Re: Product Configuration Guide
    I people can confirm it works, I would be grateful!
  • 04-20-2007 1:08 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Peter is does not seem to be working.
    CraigBig Smile
  • 04-20-2007 1:35 PM In reply to
    Strange! Had one reply that it was! Did you remove the pdf and replace it with a .exe - also try putting a space between Product, guide and configuration!
  • 04-20-2007 2:23 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Downloaded, installed and runs just fine - fancy that!Wink
  • 04-20-2007 2:32 PM In reply to
    can confirm that it installs ( albeit a bit slowly ) and works on my Windows XP laptop, it is worth the effort, as it really does spell the config when using masterlink in different link rooms with different kit  Smile
  • 04-20-2007 2:56 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I already have it installed on my PC from the old forum, so don't want to risk wiping it off only to find I can't get it to work again!
    Andy T.
    Poor me, never win owt!
  • 04-20-2007 4:33 PM In reply to
    Have been told that this is an old version - can't check on a Mac so I am loading a newer one!
  • 04-20-2007 5:32 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Installed and working. Could be usefull for the future. Thanks
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 04-20-2007 10:02 PM In reply to
    • Corvin
    • Top 500 Contributor
    • Australia
    • Posts 124
    No Beosystem 3 that i can find!
  • 04-21-2007 7:47 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    i think this is an old version, there is no bl7, no bs4, and i thing there are many other products missing from the lists.
  • 04-21-2007 7:57 AM In reply to
    I have put the newest there is on! There are now two - an old one which I will remove and the new version 2.54 . I cannot really help with these as they do not run on my Mac!
  • 04-23-2007 5:12 AM In reply to
    Thanks again Peter, have downloaded the updated version and installed it with no problems. By the way in case it helps other users I am running this on a laptop running XP SR2.
    Please let me know what problems others are having and I will certainly do my best to help
     Steve
  • 10-26-2011 5:51 PM In reply to
    Hi Peter,
    Is the software still available? I try to find it on the website but was unable to get it...
    cheers,
    sergio
  • 11-14-2011 11:18 AM In reply to
    • RaMaBo
    • Not Ranked
    • Joined on 11-09-2011
    • Munich / Germany
    • Posts 8
    • Gold Member
    sergi0:
    Hi Peter,
    cheers,
    sergio
    Hi sergi0,
    i found the software here but i can't let it run, after installing it gives me an error stating that the win16 subsystem doesn't have enough ressources to run BOCONFIG. Click on OK and restart computer
    The computer is 32Bit XP SP3 incl. all MS patches.
    Maybe Peter or Keith have any hints for this problem?
    Regards
    Ralph-Marcus
    My Beo: ... Beovision 3-32,  BeoCenter 2500,  BeoLab 8000,  BeoLab 2000,  BeoLink 1000, 5000, 4,  LC2,  BeoCom 6000 ISDN,  BeoCom 2500,  BeoTalk 1100,  VDR (Linux based Twin-Sat Receiver),  Teac WAP-4500 ((W)LAN Streaming Client with Internetradio),  A8,  A9  ...
  • 11-14-2011 1:14 PM In reply to
    RaMaBo:
    I suppose you used the upper of the links (announced as "latest")?
    Just tried it on my laptop (32-bit Vista) and it works fine without any tweaks, but you need to run the installer as administrator.
    Obviously the installer needs to finish without any errors. If it did, but you still get the above error, you might try to run it in Win95 compatibility mode, or something...
    The actual program seems to be ancient (it's probably a 16-bit program predating even Win95!) and they have just added a more modern installer and updated the product info. The user interface is terrible Big Smile
    -mika
  • 11-14-2011 2:35 PM In reply to
    Downloaded, it works fine.
    And I found a very interesting point, according to the "conclusion" thought only the TV show cheaters used that term... LaughingLaughing The BV10 can provide Beolab 5's with source data in a masterlink setup with the Beolab 5's connected to the BV10, thus enabling them to listen for the spdif input when in speaker mode 2???
    Anyone can confirm this?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 11-14-2011 2:36 PM In reply to
    Sidenote, to get the program working I had to run the win2000 version.
    -Andreas
  • 11-15-2011 7:52 AM In reply to
    I could install the program on my Win7 System without problems. But I cannot start it because it says it is not compatible. Seems windows requests a 32bit or 64bit version...
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-15-2011 8:43 AM In reply to
    Heribert:
    If you have the 64-bit version of Windows 7, it will not natively run these old programs. It lacks the 16-bit subsystem completely.
    You could install some virtual machine software, install some older version of Windows in that and try that way - but frankly, it isn't worth going through hoops just to run the PCG.
    -mika
  • 11-15-2011 9:32 AM In reply to
    • RaMaBo
    • Not Ranked
    • Munich / Germany
    • Posts 8
    • Gold Member
    I installed the newest version and it installed well without any errors but it gave me the mentioned error.
    The problem was Win XP itself: After hibernating the machine the last 2-3 months and no restart during this time it was just time to boot the whole machine and tadaa! The Product Configuration Guide started well and run quite smooth but the user interface is really terrible [:'(]
    Regards
    RaMaBo
  • 11-16-2011 5:11 PM In reply to
    thanks a lot for the link I was not able to find... shame on me ;)
    I confirm that you have to run a 32 bit OS in order to use this tool. I use it inside a virtual machine and it works well!
    but... the interface is so 95!!!! incredible ;)
