Idag er beo 5 lanceret OFFICIELT
Masser af nye billeder og information er lagt frem på B&O´s Hjemmside. Jeg har ringet til min lokale B&O forretning og de oplyser at
prisen bliver danske kr 4195,- inklusiv den nødvendig bordlader, og kr 3595,- uden bordlader (hvis du har f.eks anskaffer dig flere Beo5 )
En demo model levereres til forretningen i slutningen af denne månede (d. 17) hvor den herefter kan bestilles..
Meget interesante tekniske data herunder
Beo 5 - Specifications
DESIGNER | David Lewis |
Battery capacity | |
Standby | 12 days |
Active time | typical 18 hours ( 3 hours continually) |
Charging time | 5 hours |
Memory | 100 logos, 100 icons, 24 zones |
Fonts | 7 fonts (1 font in 7 colours) |
IR operation | Beo4 IR protocol, Beo5 IR protocol, RC5, Bitstream, NEC and Raw |
Hard keys | Yes, 17 + wheel |
Soft keys | Yes, 17 |
Warning for low battery | Yes |
Operation in charger | No |
Multiple languages | Yes, 8 |
Wake-up touch | Yes |
Table charger | With update functionality (for dealers and Technicians) |
Cable length | 3.6 meter |
| 205g +/- 5g |
Dimensions | |
Width | 69.3 mm |
Height | 115.8 mm |
Depth | 32.3 mm |
Operating temperature range | |
Complying with all specs | 10 C to 50 C |
Reduced performance is acceptable in range | 0 C to 10 C |
IR range | 455 KHz and 2080 KHz |
Power management | Mini DIN (4-pin) |
Wake-up | Alu-ball touch, key-press, display pressing, wheel activation, placing in charger |
Power down | Timeout - follows backlight |
Power on | Centre key activation, placing in charger |
Power off | Long press on centre key, low battery capacity (<10%) |
Battery and charging | |
Active time pr. charging | typical 18 hours (3 hours continually) |
Standby time pr. charging |
| 12 days |
| < 5 hours from empty |
| 5,0V DC +/- 10% |
| 400mA +/- 10% |
| Beo5 Charger Table - type number 8003080 |
| Access by service technician |
Easy volume adjustment with the wheel | |
Volume adjustment is carried out with the wheel | |
Wheel functions | Volume up, volume down, mute |
Backlight | |
Colour | White |
Intensity | Automatic adjusted to ambient light |
Timeout | 2 step - dim and fadeout |
| Factory set to 10 and 30 seconds, user adjustable |
Display function | |
Type | Delta-RGB, 320x240 pixels, normal black |
Colour | 16.777.216 colours |
Contrast ratio | 500 @ 25C (typ) |
Function | Factory adjusted contrast |
Visual signals | |
In standby | None |
Active | Display - "Battery low" |
Sounds | |
Wheel | turning |
Display | touch - select & release |
